Spare Tire Question
Old May 13, 2007 | 09:46 PM
bohunk's Avatar
bohunk
Spare Tire Question
Can I use a Saturn SL2 wheel for a spare tire for my MCS? The specs are:
15 inch X 6 inch wheel, 50 mm offset.
Thanks!
Old May 14, 2007 | 04:51 AM
NMgokart's Avatar
NMgokart
Not sure, but I think the offset might be the killer.
Old May 14, 2007 | 04:58 AM
JAB 67's Avatar
JAB 67
Among other considerations, the bolt pattern needs to be 4x100.
Old May 14, 2007 | 05:01 AM
rubyred3's Avatar
rubyred3
also, worry about the hub bore, you might need to use a hub ring with it, although depending on the design of the wheel, that might not even work. If the hub bore is too big, it will wobble. I suppose this isn't the biggest deal, considering it would be for temporary use anyways, but you'd really need to watch your speed to be safe.
Old May 14, 2007 | 05:21 AM
cristo's Avatar
cristo
Alliance Member
Saturns have a 57.1 mm bore 1 mm larger than MINI.
Old May 14, 2007 | 01:00 PM
bohunk's Avatar
bohunk
Is that bad? I mm of slop doesn't sound so bad. Should I try it?
Old May 14, 2007 | 01:02 PM
rubyred3's Avatar
rubyred3
1mm is enough to call it not concentric (1mm off is significant). However, if you drive carefully and slowly, and don't drive a long ways on the spare (you should do all these things anyways) you should be fine.
Old May 14, 2007 | 02:41 PM
Crashton's Avatar
Crashton
Yes the wheel is not hub centric to the MINI hub. I'd have to say if it bolts on & clears the brakes go ahead & use it. Temp spares are only to be driven on slowly & for short distances anyway.
Old May 14, 2007 | 05:21 PM
rosmakloma's Avatar
rosmakloma
Didn't someone write about a Chevy Cobalt spare working for the MINI?
Old Sep 28, 2007 | 02:24 PM
DaveMo's Avatar
DaveMo
Hi folks,
Just another point of reference on this: I bought a used space saver spare from a Saturn SL2 and it bolted on the Mini just fine.
Dave
Old Sep 28, 2007 | 06:27 PM
buzzsaw's Avatar
buzzsaw
Chevy Cobalt and Mazda Miata are said to be a fit-check your local listings before purchase.
kazyn
Oct 25, 2019 02:34 PM
madmax88
Aug 21, 2017 07:07 PM
TJANK
Aug 24, 2015 06:11 PM
blackie
Aug 23, 2015 08:44 PM
Mrdi
Aug 7, 2015 01:06 PM
