Drivetrain Cleaning the Inside of the Intercooler
Old May 12, 2007 | 10:47 AM
shankrabbit's Avatar
shankrabbit
With all the talk of oil catch cans and dirty intercoolers I wanted to get a first hand experience as to just how much oil gets collected inside of an IC with no catch can.
Since I'm a "spirited" driver I figured I'd have some dirtiness on the inside but found it was a little more then I expected.
I cleaned out the IC just before heading down the Dragon and took a bunch of pictures. As with all things I do to Claire, I took the pictures and did a little write up.
How to Clean the Inside of the Intercooler
I also was a little unsure on just how the heck oil got into the IC in the first place so I did a little research and wrote up and overview. I figure information is only good if people share it.
Overview of Intercoolers and Oil in them
Let me know what you think... or questions... or comments. I dig them all.
Last edited by shankrabbit; May 12, 2007 at 02:54 PM. Reason: Stupid Hosting---is back up now
Old May 12, 2007 | 11:11 AM
MINIFVR's Avatar
MINIFVR
This is very helpful. I was reading a thread on WMS which discussed how to insulate the stock IC with silcone foam and reflective aluminum to increase the TE. (If anyone wants that link, let me know). I am planning on doing that and I wanted to clean the IC at the same time...now I know how to do it properly! Thanks.
Old May 12, 2007 | 11:24 AM
ARTSJCW's Avatar
ARTSJCW
shankrabbit
Thanks!!!!
Very informative.
Old May 12, 2007 | 05:08 PM
NMgokart's Avatar
NMgokart
Addendum to step 6: Before tightening IC boot bolts, make sure the 4 IC diverter bolts line up properly.
Repeat: make SURE the 4 diverter bolts line up!!!!!
Old May 12, 2007 | 06:01 PM
shankrabbit
How did you get the rubber boots to sit right if the diverter bolts didn't line up?
I'm have a feeling you have personal experience with this? Do tell!
Old May 12, 2007 | 07:35 PM
NMgokart's Avatar
NMgokart
Personal experience? Ummm, yeah. Just installed the Alta silicone boots last night. The IC can sit any number of places whilst in the boots. There is approx 1 inch of free space between the IC ends and the horns; elsewise, you'd never get it in place. There will be some left/right adjustability once both ends are socketed in the boots. Easy enough to line up: just drop the longer upper bolts in place before tightening the boot clamps and pry left/right until you can get the threads started. Then tighten the boot clamps.
HTH
Old May 12, 2007 | 09:38 PM
shankrabbit
HTH
Ahhh... the Alta boots... that would explain it.
With the "accordian" style OEM boots, lining up the IC happens pretty easily from my experience.
Thanks for the heads up though. I'll add a little note to the write up.
Old May 13, 2007 | 05:53 AM
THE ITCH's Avatar
THE ITCH
The torque on the intercooler bolts and diverter bolts is 7 ft/lbs. Tighter is not always better!
Steve
Old May 13, 2007 | 07:27 AM
MINIFVR's Avatar
MINIFVR
I read somewhere that the Alta boots are not of very good quality... Is there really a big difference between the OEM, Alta, and other aftermarket boots?
Old May 13, 2007 | 12:03 PM
Sunracer's Avatar
Sunracer
Webb insulation info
I'd like to know where to find it-PB
Old May 13, 2007 | 09:47 PM
shankrabbit
Steve
Eeep!
Thanks for that heads up!
I'll make the change.
Colt45Magnus
Aug 27, 2024 05:03 AM
W0TM8
Dec 19, 2019 07:50 AM
rtk90
Aug 29, 2019 09:08 AM
MasterShaftner
Sep 4, 2015 03:52 PM
Sep 1, 2015 04:39 PM
