R56 How hot is my R56 running?
Old May 11, 2007 | 07:12 AM
vlonjati's Avatar
vlonjati
Hi everyone, I have been driving my MCS for a little over than a week now and I keep wondering how hot my engine temp is? Is there a way to get a reading? Can there be a way to find out the temperature?
Please let me know.
Also I wanted to add the unlike my Volvo S40 this car does not rev up for a minute or so at initial start up. Why is that? I thought the Volvo does it to warm up a bit.
Weigh in guys.
Old May 11, 2007 | 07:22 AM
Loony2N's Avatar
Loony2N
Because Volvo is owned by Ford and MINI is owned by BMW. I would like to know about the temp, too.
Old May 11, 2007 | 02:03 PM
Evergreen's Avatar
Evergreen
Our regular cooper revs higher than usual at start up then idles back down after a few minutes.
I third the engine temp inquiry. All I could find in the owners manuel about it was a warning light that comes on when it overheats. Any more thoughts?
Old May 11, 2007 | 02:11 PM
dneal's Avatar
dneal
Do you post on the Swedespeed forums? Anyway, I traded my '05 S40T5 on the Mini. Your S40 has an initial high idle in order to warm the catalytic converter up.
Old May 11, 2007 | 03:23 PM
EENY's Avatar
EENY
I'd be slightly reassured if I knew that the temp warning light had 2 colors - yellow, then red. However, I'd guess it is only one color - emergency!
Old May 11, 2007 | 03:57 PM
mommashine's Avatar
mommashine
i've always been told on my previous vehicles that if the light comes on it's already too late... however... i have a feeling that everything is so sensitive on our minis that when it comes on, we probably have time to do something... course that's my unprofessional opinion...
Old May 11, 2007 | 04:13 PM
z3bum's Avatar
z3bum
There is an ODBII connector on the MINI that can be used to read the actual temperature sensors. You can read engine coolant temperature, and a number of other parameters... see the link below. You need a compatible PDA (palm or ppc) an adapter cable that is ODBII to the device and some software. I use this... http://www.auterraweb.com/scantoolsoftware.html
Old May 11, 2007 | 06:33 PM
mommashine's Avatar
mommashine
ooooo funness... :-D
Old May 11, 2007 | 08:53 PM
vlonjati's Avatar
vlonjati
Yeah I have been on that neck of the woods, "Swedespeed" land.
By the way I did the same I traded in my s40 2.4i for the new MCS. It went somewhat like this.
I walked in the show room thinking of the old days when I drove a mini. The sales man that sold me the 04 mini three years ago jumped of his chair and cam running towards me. He proceeded to smile like child and ask me if I had test driven the new 07. He said that it was way way better. I test drove it and in two hours walked away with my "Little Rocket". I love it.
By the way thank you all for trying my initial question. Still hopping to hear someone say that they discovered a hidden menu where that info could be seen.
Ciao
Old May 11, 2007 | 09:07 PM
Partsman's Avatar
Partsman
Legion_of_Doom
Please let me know.
Weigh in guys.
To read the actual coolant temp in real time, you can use one of these...
http://cgi.ebay.com/ebaymotors/ScanG...spagenameZWDVW
Not sure why there is no "high idle" at start up, maybe someone else will chime in.
Old May 11, 2007 | 10:06 PM
Robin Casady's Avatar
Robin Casady
Anyone actually used one of these on an R56? I'd like to hear how well it works, and how to install it.
Old May 11, 2007 | 10:17 PM
ScottRiqui's Avatar
ScottRiqui
I don't have an R56, but according to the R56 owner's manual, the engine temperature light *is* a two-colour light. Of course, the owner's manual doesn't give the specific temperatures associated with the colours - only that yellow is "too hot" and red is "overheating".
Old May 12, 2007 | 05:07 AM
cristo's Avatar
cristo
Alliance Member
Use the spiffy trip odometer menu described in the following link.
Once you select 7.0 actual coolant temp. you can start
the car and drive around and the coolant temp will display until
you turn off the ignition.
How to show RPM, Fuel Level, Speed and more on your Odometer Digital Display
http://www.mini2.com/forum/faq.php?f..._obc_functions
Old May 12, 2007 | 10:07 AM
Ryephile's Avatar
Ryephile
From what I've seen with the OBDII scan-tool, the car levels out it's operating temp at about 230F, which is about 10F warmer than the R53 runs.
Old May 12, 2007 | 10:21 AM
Robin Casady
Where is the OBDII connector? How do you access it?
Old May 12, 2007 | 10:40 AM
EENY's Avatar
EENY
I see this now.
On pg 44 the manual just mentions that the warning light will come on. But on pg 119 it indicates that it will light up in yellow ("continue driving at more moderate speed so that the engine can cool down"), and red ("bring the car to a stop, switch the engine off and allow it to cool down. Do not open the bonnet otherwise there would be a risk of injury by scalding").
Thank you
Sexual Chocolate
Mar 31, 2019 08:02 PM
danielbrookes_9
Oct 3, 2015 12:51 PM
jwmolmen
Sep 22, 2015 10:00 AM
ltjpunk7
Sep 6, 2015 07:32 AM
