MidCal MINIs MidCal MINIs...filling the MINI void between Northern and Southern California. Visit the club site at midcalminis.com
A Big Thanks
Old Jan 11, 2007 | 03:37 PM
  #5351
ChrisW's Avatar
ChrisW
Originally Posted by Scooby03
1-set rear control arms
1-set front end links
1-set rear end links
What would the install run me or is it something i could do in a weekend myself?
Old Jan 11, 2007 | 03:40 PM
  #5352
Scooby03's Avatar
Scooby03
I will have to ask Steve when he gets here tomorrow.
If you are doing the coilovers yourself, then the rest is easy.
Old Jan 11, 2007 | 03:43 PM
  #5353
1nf3rn0's Avatar
1nf3rn0
Easy as pie. Control arms take some wrestling to get them into place though...
  #5354
ChrisW's Avatar
ChrisW
OK thanks, Do you remember how long it took you to put yours in?
Old Jan 11, 2007 | 03:44 PM
  #5355
ChrisW's Avatar
ChrisW
OK then i will most likely do it myself and spend my money with you guys in other areas.
Old Jan 11, 2007 | 03:45 PM
  #5356
1nf3rn0's Avatar
1nf3rn0
Control arms take an hour. The end links are plain simple. half hour to an hour for front and rear. Like I said before though, hold off on the end links unless you find you actually need them.
Old Jan 11, 2007 | 03:47 PM
  #5357
ChrisW's Avatar
ChrisW
I thought you had to change the end links if you started using camber plates
Old Jan 11, 2007 | 03:48 PM
  #5358
Scooby03's Avatar
Scooby03
We did ours up at Steves house. 1st coilover install. Took a bit to get the right settings. Should be a lot easier on yours.
If I remember, 2-days. Front one day, rear one day.
Old Jan 11, 2007 | 03:49 PM
  #5359
Scooby03's Avatar
Scooby03
Depends on how low and the camber. Ours put a bind on the swaybar, so we put them on.
Old Jan 11, 2007 | 03:55 PM
  #5360
ChrisW's Avatar
ChrisW
I see ok, well i better just get them right off the bat then.
Old Jan 11, 2007 | 03:59 PM
  #5361
1nf3rn0's Avatar
1nf3rn0
Your money...
Old Jan 11, 2007 | 04:00 PM
  #5362
Scooby03's Avatar
Scooby03
We both have them on our MINI's. We also have upper and lower rear control arms. Steve made a bracket for the headlight sensor.
  #5363
Scooby03's Avatar
Scooby03
Did you buy the set from Michele?
Old Jan 11, 2007 | 04:03 PM
  #5364
ChrisW's Avatar
ChrisW
Not yet i have about 3/4's of it saved up now i just need to come up with the rest. So it will most likely be early feb when i buy them. I just wanted to see how much more i needed to save up to have them on the car by AMVIV.
Old Jan 11, 2007 | 04:04 PM
  #5365
Scooby03's Avatar
Scooby03
After install, you will need to get it aligned
Old Jan 11, 2007 | 04:13 PM
  #5366
ChrisW's Avatar
ChrisW
i know David and i talked about that today, Do you remember how much it is?
Old Jan 11, 2007 | 04:15 PM
  #5367
Scooby03's Avatar
Scooby03
I think Steve paid $140 or so. Depends on what you do. Its getting easier for him now.
Dave is very cool
  #5368
1nf3rn0's Avatar
1nf3rn0
~$200 depending on the shop. If you file the openings on your strut towers, it makes it alot easier.
Old Jan 11, 2007 | 04:17 PM
  #5369
Scooby03's Avatar
Scooby03
Dave is nicer than that
Look at Steve's to see what Blake is talking about.
Old Jan 11, 2007 | 04:22 PM
  #5370
ChrisW's Avatar
ChrisW
Dave is very cool
Gees do they make anything Cheap on thiese things.
  #5371
ChrisW's Avatar
ChrisW
Yea i saw steves i don't want to do that if i can get away with it. Do you have it done?
Old Jan 11, 2007 | 04:24 PM
  #5372
1nf3rn0's Avatar
1nf3rn0
Not yet. I have a dremel ready to do it soon.
Old Jan 11, 2007 | 04:25 PM
  #5373
Scooby03's Avatar
Scooby03
Nope, and don't plan to. I'm not going to adjust mine.
Old Jan 11, 2007 | 04:28 PM
  #5374
ChrisW's Avatar
ChrisW
ok so i don't have to do it as long as i'm ok with the settings. I can live with that.
Old Jan 11, 2007 | 04:36 PM
  #5375
1nf3rn0's Avatar
1nf3rn0
I don't have that luxary.
