FS:: R60 Brembo JCW "GP2X" 6-Piston BBK - Calipers/Rotors Big Brake Upgrade
Old 02-11-2020, 10:11 AM
CG1*'s Avatar
CG1*
CG1* is offline
Category: Brakes
Price: $2450
Location (Region): Midwestern
A while back, we busted out a custom F60 BBK for my boy. Deets HERE. Since then I’ve been prompted to work on one for an R60 owner that would be a bit more OEM in style. What is more OEM than the kit that Mini SHOULD have issued for the R60 in the first place? Sometimes you just have to do the job yourself. That is, make the "GP2X” big brake kit, of course …
Application:
  • R60 Countryman (’11-‘16) – 5x120 lug, 79mm CB
Front:
  • Calipers: OEM GP2/135i units - REFINISHED - OEM motif: Mold seams shaved, artwork is painted on using catalyzed urethane.
  • Rotors: 2 x Centric High Carbon 125 Series 350 x 25mm - NEW - Dimpled in Brembo 32-row pattern
  • Pads: 1 x Powerstop Z16 Evolution - NEW - Ceramic, low dust
  • Brackets: Custom worked for the 350mm rotors and R60 spindle.
Rear:
  • Calipers: OEM JCW units - REFINISHED - OEM motif: Custom vanity plate recessed and adhered (epoxy) with the artwork painted on (wet on wet for a chemical bond). Brackets: texture ground off the face and coated in a contrasting matte black.
  • Rotors: 2 x Centric High Carbon 125 Series 296 x 10mm - NEW - Dimpled in matching Brembo 32-row pattern
Notes:
  1. Selling as complete package only – This is the only one if its kind.
  2. Make sure your wheels will clear the front 6-piston units. Dust shields may need trimmed or removed to fit the massive front binders. You can use the GP2 template by matching up the OD’s of the two center bores.
  3. GP2 TEMPLATE
  4. Accessory items like lines, sensors, and fluids are not pictured or provided.
  5. **Ensure that your installer (if you're not a wrench) will install aftermarket parts.**
The following 3 users liked this post by CG1*:
burton182boarder (03-03-2020), MannyJimenez (02-13-2020), stage1scott (04-18-2020)
Old 02-21-2020, 05:24 AM
I_Forge_KC's Avatar
I_Forge_KC
I_Forge_KC is offline
Anybody else feverishly collecting soda cans to make some extra pennies?
These look amazing...
The following 3 users liked this post by I_Forge_KC:
Black Forest (02-25-2020), OSilvera (05-18-2020), Ray167 (03-19-2020)
Old 02-25-2020, 08:59 AM
CG1*'s Avatar
CG1*
CG1* is offline
Yeah, this was a fun little project. Despite not owning an R60, I've always been bothered that red paint was nearly all that separates the JCW brakes from the base model. Add that this chassis is a bit taller/heavier, and that the JCW wheels are 19", and next thing I know there were 350mm rings in my shopping cart.
In my mind, every R60 should look like this ...
Incidentally, these have been moved to Ebay.
burton182boarder (02-26-2020), Cooper_Si (08-14-2023), stage1scott (04-18-2020)
Old 02-25-2020, 09:38 AM
njaremka's Avatar
njaremka
njaremka is online now
Alliance Member
Received 1,723 Likes on 1,387 Posts
You, sir, do some nice work
The following 2 users liked this post by njaremka:
burton182boarder (02-26-2020), stage1scott (04-18-2020)
Old 03-04-2020, 11:15 AM
CG1*'s Avatar
CG1*
CG1* is offline
Appreciate it.
burton182boarder (03-10-2020)
Old 03-18-2020, 12:03 PM
CG1*'s Avatar
CG1*
CG1* is offline
sold.
Old 03-18-2020, 04:49 PM
iwashmycar's Avatar
iwashmycar
iwashmycar is offline
Congrats! I just love drooling over the photos!.
Old 04-19-2020, 12:11 AM
B2FiNiTY's Avatar
B2FiNiTY
B2FiNiTY is offline
this is simply amazing.
Old 06-14-2020, 07:33 AM
checkered·JCW's Avatar
checkered·JCW
checkered·JCW is offline
Exclamation
Originally Posted by CG1*
sold.
You planning on making up any more of these? Interested in getting a set if possible.
burton182boarder (06-24-2020)
Old 06-24-2020, 01:20 PM
burton182boarder's Avatar
burton182boarder
burton182boarder is offline
same question as above...are you making more of these?! if so when? I want them too! amazing work!
Old 06-24-2020, 10:06 PM
CG1*'s Avatar
CG1*
CG1* is offline
Again, I appreciate the compliments. I have some ideas in the pipeline. I just have a few gaps to bridge before I get started.
For anyone thinking about a kit like this, make sure you have around 2.5" between the back of your spokes and the outside rotor face. That means either running spacers or getting some big boy wheels mounted up.
Old 12-15-2020, 08:00 AM
CG1*'s Avatar
CG1*
CG1* is offline
Save your Christmas money.... round two is just around the corner.
I_Forge_KC (12-15-2020)
Old 02-23-2021, 06:59 AM
veggivet's Avatar
veggivet
veggivet is offline
Will these be compatible with the Paceman? (R61)
Old 02-23-2021, 10:46 AM
CG1*'s Avatar
CG1*
CG1* is offline
Yeap. They share the same spindles, so the same caveats would apply as well.
Old 03-04-2021, 03:57 PM
burton182boarder
Bbk
are these still available?
Old 03-25-2021, 07:27 PM
CG1*'s Avatar
CG1*
CG1* is offline
They were. Until you had me ship them to Vermont. I just needed a good reason to finally finish this set.
Set #2 (Peep Show):
Billdone
10-10-2019 10:12 PM
nachodave96
08-15-2019 10:21 AM
CG1*
04-11-2019 07:17 AM
cerenkov
03-08-2017 02:31 AM
BRracing
02-08-2013 06:05 PM
Quick Reply: FS:: R60 Brembo JCW "GP2X" 6-Piston BBK - Calipers/Rotors Big Brake Upgrade
