JCW Running some E85 in Mini Cooper JCW
Old Jan 21, 2020 | 02:05 PM
Darbys2019MiniJCW's Avatar
Darbys2019MiniJCW
I have been running E85 in my 2019 JCW and it is great. It is cheaper than any "OCTANE BOOST" bottles and it has caused no problems.
11.5 gallon tank...some people run 3.5 gallons but I run 2.0 gallons (a 17% Mixture)
I started after the MarioKart Tune and love it...NM Power Module was "Good"...the MarioKart RPM Tune is "Great" IMO
First AutoX coming up Feb 1st...we will see
Old Jan 21, 2020 | 04:08 PM
MrGrumpy's Avatar
MrGrumpy
Run the same mix per Mariokart, the car seems very happy with it. Been doing it for over a year and a half.
Old Jan 22, 2020 | 06:29 AM
DavidPinAZ's Avatar
DavidPinAZ
I'm very curious as to real world differences you notice with E85, and octane boost, if you don't mind?
Old Jan 22, 2020 | 07:50 AM
Darbys2019MiniJCW
PRICE...I bottle of Octane Boost is $7 and up and states it might raise Octane by 3 points
E85 or Ethanol at 10 % raises Octane in Pump Gas a few points
Bump it up to ~17% and 93 Octane is at 95 Octane or better
My Torque App shows a lower operating temperature but that could be because of the MarioKart RPM Tune
The best thing is so far??? Under Full Boost at 6500rpm the AFR (Air to Fuel Ratio) runs a steady 11.4-11.6 so it is not running lean and pulling better at high rpms...during normal cruising the AFR is at 14.2-14.7 or so
Old Jan 23, 2020 | 05:16 AM
DavidPinAZ's Avatar
DavidPinAZ
Perfect, thanks!
Old Jan 23, 2020 | 07:43 AM
Darbys2019MiniJCW
Perfect, thanks!
And I am leaning on the conservative side...it is probably even better boost but better safe than sorry...
Say 2 Gallons at 2.25 per gallon so 4.50 PLUS you get fuel mileage out of those 2 gallons compared to NO Measureable FUEL MILEAGE out of a 12oz Octane Boost
Old Feb 20, 2020 | 12:32 PM
LOLOLIVER's Avatar
LOLOLIVER
And you’re filling up with e85 from a standard e85 station? Nothing fancy?
Old Feb 20, 2020 | 12:48 PM
Darbys2019MiniJCW
Yep...from a Shell Station in New Braunfels, Texas. It has one Pump (each side of the pump) and then I top off the other with 93 Octane.
MarioKart says U can use 3 gallons for each fill-up which is about 27% E85
johntotah94
Jun 13, 2021 02:48 PM
mini4mo
Oct 26, 2015 08:02 AM
BadgeFTW
Oct 9, 2015 03:44 PM
Phx JCW
May 24, 2012 07:07 PM
Haz
Feb 14, 2003 07:45 AM
