JCW Please provide (1) average mileage, and (2) average speed for your JCW - thank you
Old Nov 23, 2017 | 04:20 AM
  #26
cmt52663's Avatar
cmt52663
Thanks for the data - any other takers? I agree this is getting interesting...
Cheers,
Charlie
Old Nov 23, 2017 | 07:37 AM
  #27
MoBoost's Avatar
MoBoost
26.2 mpg
37.7 mph
Manual transmission
Old Nov 23, 2017 | 07:10 PM
  #28
SFMCS's Avatar
SFMCS
Exclamation
Charlie,
Please enlighten me as I do not understand what your chart is attempting to portray.
Example: I take my '15 MCS (JCW tune/sport mode) from a dead stop and aggressively accelerate, run the gears and attain 80 mph. My average speed will be around 45 mph and I am sure that the mpg will be in the 20's or below. I will be happy to test this assumption.
A more accurate study would be to chart a MEDIAN CONSTANT speed with mpg/ per gear. That would entail driving on a level/smooth surface, holding a constant speed/gear. Not sure if the MINI info will do this, perhaps resetting the trip odometer will. I will check tomorrow.
One could assume that the "MINI average" was implemented to assist certain drivers to modify their driving habits for various reasons.
Wasn't there research done at a college in England that used averages in a totally inaccurate report, on a study, recently?
Old Nov 24, 2017 | 04:29 AM
  #29
cmt52663's Avatar
cmt52663
Originally Posted by MoBoost
26.2 mpg
37.7 mph
Manual transmission
Thanks very much!
Cheers,
Charlie
Old Nov 24, 2017 | 04:57 AM
  #30
cmt52663's Avatar
cmt52663
Originally Posted by SFMCS
Charlie,
I am just curious regarding what other folks are seeing for mileage and speed.
Coming from the B38, I was initially startled by the relatively low mileage from the current Gollum. I normally drive around Cape Anne at low RPM - 2k in 4th is about right (36 mph), but when I get on Route 128 and leave the island I cruise quite a bit quicker - e.g. 3.2k in top.
The majority of my driving is quite gentle, and the B38 returned 34.6 as an overall average. Despite my tendency to feather-foot, the B48 is plateaued at 28.7. It makes me curious.
I do like to see patterns in data, and I had a theory (mentioned earlier) that I might find that there would be an inverse relationship between mileage and speed, and a limit that would keep the sum under 70.
Since trouble1943 and FDR both exceed that my theory is disproved.
I am also amused to notice the relatively narrow range of average speed. I still hope that some folks from the western states may weigh in with higher average speeds, and perhaps some city-dwelling Miniacs may contribute with lower speeds.
We shall see!
Cheers,
Charlie
Old Nov 24, 2017 | 08:13 AM
  #31
SFMCS's Avatar
SFMCS
Charlie,
Thanks for the reply. Your B38 engine had a displacement of either 73 or 91 cu in (3 cylinder). The gross weight (US) was listed at 3329 lbs. The recorded average mileage (US) was 44.3 mpg.
The B48 (4 cylinder) is listed at 132 cu in and has a mileage estimate at 34.1 mpg, a gross weight of 3450 lbs (F56). No stats were given for the JCW, only the S. If anything, one would assume that the JCW would weigh more (brakes, etc).
Torque, acceleration, and top speed were not even close.
Perhaps this could explain the differences in your mpg.
Old Nov 24, 2017 | 11:33 AM
  #32
vetsvette's Avatar
vetsvette
Moderator
Charlie,
Would you be interested in info from an S with the JCW Tune + NM?
Old Nov 24, 2017 | 11:35 AM
  #33
vetsvette's Avatar
vetsvette
Moderator
Originally Posted by 2017All4
Also, the Auto stop/start function screws with the readout.
I coded that feature out and enabled "Sport" mode at startup with the bimmercode app.
Old Nov 24, 2017 | 07:19 PM
  #34
cmt52663's Avatar
cmt52663
Certainly.
Cheers,
Me
Old Nov 25, 2017 | 11:30 AM
  #35
vetsvette's Avatar
vetsvette
Moderator
2015 MCS manual with JCW Tune and NM Module (coded to permanent "Sport" mode):
2121 miles traveled since reset
30.0 mpg
43.1 mph
Old Nov 26, 2017 | 04:35 AM
  #36
cmt52663's Avatar
cmt52663
Thanks.
Cheers,
Charlie
Old Nov 26, 2017 | 03:22 PM
  #37
TexasMini17's Avatar
TexasMini17
Here is what I have
My averages are...
26.3 MPG
32.2 MPH
2017 JCW Automatic
I have just over 1500 miles on the car.
Old Nov 26, 2017 | 04:43 PM
  #38
Eddie07S's Avatar
Eddie07S
Charlie,
This is just FYI.
I know this request is for the F56 JCW and you probably don't want to muddle your data, but I thought I would provide my mileages just for comparison:
2012, MCS manual. This includes time on the track
24.6 mpg
33.2 mph
2004 MC CVT (mostly stop and start, short haul city driving:
20.2 mpg
17.9 mph
In looking at your data that you have collected, these seem to fit in, although a little on the low side. Interesting given the big differences in the cars and their engines.
Old Nov 26, 2017 | 07:31 PM
  #39
theblackfalcon's Avatar
theblackfalcon
25.3 mpg. 42.7mph.
Old Nov 27, 2017 | 04:09 AM
  #40
cmt52663's Avatar
cmt52663
Thanks very much!
Cheers,
Charlie
PS:: Sorted by Sum column just out of curiosity.
Old Nov 27, 2017 | 06:49 AM
  #41
nqr31467's Avatar
nqr31467
Charlie, My JCW is an automatic with paddle shifters. Health limitations now dictate the type of trans my car can have.
Old Nov 27, 2017 | 09:09 AM
  #42
TheBigNewt's Avatar
TheBigNewt
I have the R58 JCW with Stage 1 tune. 28.5mpg city (29 mph). 34 mpg hway (53 mph). Overall about 30 mpg. My car is quite a bit lighter than the F56 JCW (2700 lbs I think). 1.8L engine.
Old Nov 27, 2017 | 10:19 AM
  #43
67morris's Avatar
67morris
Originally Posted by cmt52663
Forgot to mention that mine is auto. It's coded to always run in Sport mode and I drive mostly in the city with 30mph speed limits :(
Old Nov 27, 2017 | 12:00 PM
  #44
theblackfalcon
If you were wanting to note. Mine has the Burger JB4, catless etc and some other mods. The more HP the worse gas mileage and tire wear I get.
Old Nov 27, 2017 | 03:24 PM
  #45
cmt52663's Avatar
cmt52663
Duly noted - thank you.
Cheers,
Charlie
Old Nov 27, 2017 | 03:26 PM
  #46
cmt52663's Avatar
cmt52663
Thanks. but as I am gathering for the B48 I will not include that data.
Sincerely,
Charlie
Old Nov 28, 2017 | 01:40 AM
  #47
cmt52663's Avatar
cmt52663
Sort by average speed - note the manual versus automatic column!
Cheers,
Charlie
Old Nov 28, 2017 | 10:21 AM
  #48
mtbscott's Avatar
mtbscott
Are you just asking for stats from a random tankful? Or is there a cumulative setting on my car I’m not aware of? Obviously my stats vary quite a bit from tankful to tankful.
Old Nov 28, 2017 | 10:27 AM
  #49
vetsvette's Avatar
vetsvette
Moderator
On your information center go to the vehicle icon > vehicle status > trip computer.
This will show you the cumulative info from the last time the trip computer was reset. In my case it was 2121 miles.
Old Nov 28, 2017 | 11:33 AM
  #50
cornjuice's Avatar
cornjuice
following data for 2012 JCW, running ~96/97oct blend of 91/E85 (cat/res delete, gap on plugs @ .027) - city driving with a heavy foot
avg speed ~48mph
avg mpg ~27.8mpg
