JCW how to lift JCW and put on Floor Jacks
Old Jun 14, 2016 | 12:16 PM
LormaD's Avatar
LormaD
Question how to lift JCW and put on Floor Jacks
I don't get it, if Mini has special lift locations, then how the #@!! are you supposed to lift the vehicle and sit on on floor jacks?
I wanted to get the jack pad adaptor, but I see that as useless since I want to use floor jacks when working under the vehicle or when it is stored for winter.
Insight please
Old Jun 14, 2016 | 07:34 PM
GregoryK's Avatar
GregoryK
They are the lift points for the jack that came with or you could buy for your car. I would not put floor stands there. There are other places once you raise the car...Also raising the front will lift the back off the ground so I suppose you could get a floor stands in the rear position.
I use a floor jack and floor stands....never a floor jack when under the car. Just occurred to me do you mean floor stands when you say floor jack?
Old Jun 14, 2016 | 07:47 PM
LormaD's Avatar
LormaD
Arrow clarity, yes
I say a floor jack, as in to raise the vehicle up off the ground. It is hydraulic, and I would never work under a vehicle supported only by a hydraulic floor jack. I have seen first hand a brand new, $200+ hydraulic floor jack blow it's seal and drop the vehicle.
I would support the vehicle by a floor jack, or jack stand. It's set, and fixed at a predetermined height, and the vehicle is then lowered by the hydraulic jack. Hence vehicle is supported by floor jack or jack stands.
After much reading, I am under the impression that the vehicle can be lifted by the centre of the front or rear axle. I am gathering that the trick is, to be sure to slide the hydraulic jack in a position that doesn't catch or damage a bolt from the front or rear cross member.
I think the design is really meant for a mechanics hydraulic lift, hence I need to buy one LMAO.
Old Jul 10, 2016 | 07:23 AM
jobexo's Avatar
jobexo
check this out...
Old Jul 10, 2016 | 09:35 AM
Fly'n Brick's Avatar
Fly'n Brick
I'll bet I've posted this blog page on this forum 50 times for just this un-explored question.
Scroll down to blimey's blog entry 'How a stud lifts a MINI'. I cut a 2 X 4 to length 8 years ago and use it many time a year for tire rotation and detailing the undercarriage.
Here's the link: http://www.blimeycabrio.com/2007/04/
Buggy
Tires, Wheels, & Brakes
Jun 16, 2016 07:23 AM
thinkMINI
Mar 29, 2016 08:43 AM
PelicanParts.com
Mar 24, 2016 09:27 AM
PelicanParts.com
Mar 22, 2016 08:44 AM
JWA
Mar 20, 2016 06:41 AM
