JCW Garage Interested in John Cooper Works (JCW) parts for your 2nd Generation MINI? This is where JCW upgrades and accessories for the MINI Clubman (R55), Cooper and Cooper S (R56), and Cabrio (R57) MINIs are discussed.
JCW Alta Compressor Recirculation Valve
Old Oct 15, 2013 | 09:43 PM
JCWKART's Avatar
JCWKART
Just installed a Alta Compressor Recirculation Valve on my 09 JCW, I'm hoping someone else could tell me if they felt a differance when they did so. Not sure why but after installing this product my car is running VERY SLUGGISH, no response what so ever. It felt way better with the stock electrical unit, the main reason i did it was to lose the check engine light i was getting on and off with the stock unit.
Old Oct 18, 2013 | 10:09 AM
solskjaer1999's Avatar
solskjaer1999
I have this installed. I wouldn't say mine is sluggish. The recirc valve does have a 'low boost purge' feature, but as soon as I put my foot down that whistling from the purge disappears and my JCW holds the boost. Is this what you're describing as sluggish? If not, I would check the connections and make sure that valve is bolted on tight. When I hear sluggish from this I think: 1) Boost isn't holding and 2) therefore there must be a leak somewhere.
Do you have the Alta AP? Perhaps that is clearing a CEL somewhere that isn't related to the O2 sensor or something. I'm wondering if the 'limp mode' is being masked somehow. I did have the resistor ends touch after hitting a pothole thereby shorting the resistor and putting the car into limp mode. The limp mode made the car very sluggish and wouldn't allow positive boost until I changed the resistor out and cleared the CEL.
Old Oct 18, 2013 | 04:55 PM
Ian Fraser's Avatar
Ian Fraser
I have one fitted to my JCW and its far from sluggish. Its the bottom end torque around town to you can feel has improved.
Is it installed properly? Did you fit the O-Ring to the valve?
Old Oct 22, 2013 | 02:42 PM
bigcooper666's Avatar
bigcooper666
You probably should have left it stock
or fix the chexk engine light at your local mini dealer
Colt45Magnus
Aug 27, 2024 05:03 AM
patsum
26
May 29, 2021 06:29 PM
bahman
Nov 15, 2019 05:45 AM
Bennyboy
Dec 1, 2016 11:09 AM
schwac2
Sep 10, 2015 07:24 AM
