JCW Garage Interested in John Cooper Works (JCW) parts for your 2nd Generation MINI? This is where JCW upgrades and accessories for the MINI Clubman (R55), Cooper and Cooper S (R56), and Cabrio (R57) MINIs are discussed.
JCW What engine Mod to Do next
Old Mar 5, 2012 | 06:52 AM
arnk0006's Avatar
arnk0006
Hello all,
I have recently purchased the following modification and I was curious to see what would be the next best modification to do.
ALTA BOV Stiffy Spring
ALTA Turbo Inlet
ALTA Intake
Invisilens odometer and tach
M7 Aerogel Heat shield for turbo
BSH Turbo boost tap
BSH OCC
Looking at future mods
Forge FMIC
FORGE intercooler piping all new
ALTA Access Port tuner / other tuner or flashing device
Possible Exhaust
Sway bars
Short shifter
Any suggestions?
What has worked best?
Old Mar 5, 2012 | 08:55 PM
bluefox280's Avatar
bluefox280
* FMIC = yes; as the OEM unit can heat soak quickly
* FORGE intercooler piping all new = not needed; the OEM boost piping is properly sized and reinforced; aftermarket pipes are more for removing excess "noise" tubes like the 'muffler' and 'noise maker'...
* ALTA Access Port tuner / other tuner or flashing device = yes; one of the best bang-for-buck modifications for the powertrain
* Possible Exhaust = owner choice; only a downpipe (mated with ECU programming) will yield increased performance, other than such it's just noise...
* Sway bars = depending on what type of driving set-up you prefer will dictate what size / application you want; typically rear is the only modified unit
* Short shifter = again, driver preference based on feel, and response
- Erik
Old Mar 6, 2012 | 09:21 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
NM torque arm bushing, no brainer do it, and it's cheap.
Hsport sway bar, again big bang for buck
YES Forge FMIC def needed in the heat of FL.
sevin
May 2, 2026 06:11 AM
Aug 21, 2015 10:07 AM
makg
Aug 21, 2015 02:49 AM
minipopkart
Aug 13, 2015 05:22 AM
