JCW Garage Interested in John Cooper Works (JCW) parts for your 2nd Generation MINI? This is where JCW upgrades and accessories for the MINI Clubman (R55), Cooper and Cooper S (R56), and Cabrio (R57) MINIs are discussed.
JCW JCW Advice Needed
Old Dec 18, 2011 | 05:53 AM
anitan1's Avatar
anitan1
JCW Advice Needed
Hey all,
I'm getting ready to pick up an '09 Factory JCW with pretty low miles (14k) and I'm wondering what I should watch out for at pick up and in the future. The car appears to be in pristine condition, although I haven't seen it in person. Can you guys offer any tips, advice, etc. that might be helpful as I enter into the JCW club?
Old Dec 18, 2011 | 05:23 PM
bluefox280's Avatar
bluefox280
Other than the standard N14 engine details like:
* maintain full oil level AT ALL TIMES
* change oil more often than MINI recommends
* timing chain tensioner
...it's pretty much the same in terms of maintenance.
Some JCW'ers have had clutches fail at early stages, but overall there's nothing "different" in terms of required maintenance compared to the standard 'S'-model (N14 / N18).
- Erik
Old Dec 18, 2011 | 06:37 PM
onefish2's Avatar
onefish2
I will add that those that had their clutches fail were early model 09s like mine. Totally gone at 2 years and 10 months with 28,500 on the odometer.
At some point MINI started using a different clutch. They knew there was a reliability issue.
Old Dec 19, 2011 | 03:32 AM
anitan1's Avatar
anitan1
Mine is an April '09 build. I'm assuming that the clutch issue is covered under warranty? Does it make noise when it fails or does it just stop working? WHat are the warning signs?
Old Dec 19, 2011 | 05:37 AM
bluefox280's Avatar
bluefox280
Typically, yes. But there have been accounts where the dealer refused replacement because of abuse / neglect versus good-faith.
Does it make noise when it fails or does it just stop working? What are the warning signs?
If not properly cared for, the clutch will slip under hard-load acceleration.
That means the RPMs will continue to climb, but the car's acceleration won't increase.
A burning smell (when pushed hard or simply abused) can be detected after driving.
One thing to prolong clutch life is not to ride or dead-pedal the clutch pedal during stop-and-go situations.
- Erik
Aug 12, 2015 01:24 PM
nomar116
Aug 10, 2015 11:24 PM
xpunisherx
Aug 10, 2015 10:50 PM
