JCW Garage Interested in John Cooper Works (JCW) parts for your 1st Generation MINI? This is where JCW upgrades and accessories for the Cooper (R50), Cabrio (R52), and Cooper S (R53) MINIs are discussed.
Rear camber links kit for a 2006 JCW
Old Apr 19, 2011 | 08:53 PM
monster13's Avatar
monster13
I am looking for a set of rear camber links from Hotchkis (tire-rack)
Do I need to purchase the upper links and lower links (more expensive) or only the lower links is enough to set up a negative camber and avoid tire wear for a daily drive as well. it's for my 2006 r53 JCW.
What camber links do you drive?
thanks
Old Apr 20, 2011 | 07:33 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
You are right on with the Hsport camber links. They are the best and quiet. Unless your building a full on race car the lower pair of links will be fine. If you want a set let me know, we can ship them USPS to save you shipping.
Old May 4, 2011 | 01:07 PM
quikmni's Avatar
quikmni
Your 06 has some adjustment for rear camber. Unless you have lowered your car more than JCW springs you should be good with the stock adjustment range.
I used the H-Sport rear lower control arms on my 03 MCS and thought they were great.
Old May 4, 2011 | 03:06 PM
cmt52663's Avatar
cmt52663
I am using Hotchkis LCA only in combination with an H&R coil over set which lowers the car about 2".
I am completely satisfied with this arrangement, and it has offered no trouble in 120,000 miles of use.
I installed them to establish 1 degree of negative rear camber, which suits my requirements.
Highly recommended.
Charlie
Old Jun 3, 2015 | 12:50 PM
Schmagagled's Avatar
Schmagagled
So MCS to JCW rear should be okay without new arms?
Just to confirm, because the Atlanta Mini parts counter that sold me the "last JCW suspension kit in the US" convinced me to buy new upper arms at the same time.
So I didn't need them afterall?
Thanks,
Schmagagled
'05 MCS JCW, with JCW suspension in progress.
Old Jun 3, 2015 | 01:04 PM
quikmni's Avatar
quikmni
I do not know why you would need to replace the upper arms because they are just the standard non-adjustable arms. Your original upper arms should be fine.
Dec 23, 2015 10:36 AM
Mini'mon
Aug 26, 2015 01:02 PM
Aug 7, 2015 05:56 AM
Aug 7, 2015 05:55 AM
