JCW Garage Interested in John Cooper Works (JCW) parts for your 2nd Generation MINI? This is where JCW upgrades and accessories for the MINI Clubman (R55), Cooper and Cooper S (R56), and Cabrio (R57) MINIs are discussed.
JCW Fitting a JCW Air Filter Housing
Old Aug 27, 2009 | 07:26 PM
Tenntony's Avatar
Tenntony
Hi,
I am looking for any tips for installing a JCW air filter housing to my 07 S. I do have a JCW strut brace on the car. The factory installation instruction sheet I have makes it look simple. Just want to be sure it is.
Thanks, Tony
Old Aug 28, 2009 | 06:15 AM
slinger688's Avatar
slinger688
Originally Posted by Tenntony
Hi,
Thanks, Tony
There are two different JCW strut braces, one for regular air boxes and one for the JCW airbox. The regular brace will not fit the JCW air filter housing.
The JCW air filter box top install is just a removal of some torx screws and the MAF clamp.
Old Aug 29, 2009 | 11:17 AM
n1tr0's Avatar
n1tr0
Make sure if you're getting the JCW airbox that you also get the rubber gasket for the base (only an issue if you ordered it separate from the stage1 kit) and like Slinger said, there were 2 different style JCW braces, hopefully yours works.
Old Aug 29, 2009 | 11:51 AM
Tenntony's Avatar
Tenntony
Like Slinger said, there were 2 different style JCW braces, hopefully yours works.
What is the difference between the two braces?
Tony
Old Aug 29, 2009 | 03:34 PM
slinger688's Avatar
slinger688
Tony
The difference is in the arc between the two anchor points (strut towers). The one for the JCW box has a greater arc to fit the higher JCW box. The regular JCW brace is more straight.
Old Aug 31, 2009 | 12:33 PM
Tenntony's Avatar
Tenntony
Guys,
Thanks for for the help. From what I could find out the strut brace that will work with the JCW Air Box is part number 51 71 0 442 352. The one that was put on my MINI was 51 71 0 444 451 which is straighter and will rub against the air box.
Tony
silence2-38554
98
Sep 21, 2016 02:52 PM
minipopkart
Aug 13, 2015 05:22 AM
Aug 12, 2015 01:24 PM
M7Speed
Aug 6, 2015 01:48 PM
