JCW Garage Interested in John Cooper Works (JCW) parts for your 1st Generation MINI? This is where JCW upgrades and accessories for the Cooper (R50), Cabrio (R52), and Cooper S (R53) MINIs are discussed.
Help with engine stutter
Old Oct 6, 2008 | 10:38 AM
Philip Rushing's Avatar
Philip Rushing
Hey, folks, I have a problem that I KNOW I instigated, but not sure how or why. (2004 JCW)
Symptom(s) first:
Pronounced engine stutter at moderate to open throttle, but none at modrate acceleration or at steady speed. This morning I was on cruise control and climbing one of east Tennessee's mountains and it reached the throttle point at which the stumble occurred, and before I was able to override the CC, the check engine light began to blink. I immediately pulled over and cut the car off. Upon restarting, check engine light stayed on, but was not blinking, so I continued to work. Same deal with stuttering, but no worse. My fuel economy has not changed.
Now here are the contributing factors:
10 days ago I changed the spark plugs (NGK laser iridiums) plug wires (magnecor), belt (gatorback) oil & filter, Redline MTL transmission fluid, cleaned & re-oiled air filter. Plugs were torqued per specs, but I have not gone back over them. The coil wire on #2 or #3 was rusted and I cleaned it (as per a previous post)
I will try to find an auto store with a code reader and go forward, but are there any "aHA! I know exactly what is going on!!" thoughts out there?
Thanks in advance
Philip
Old Oct 8, 2008 | 02:04 PM
Philip Rushing
Never mind. "#2 cyl misfire" Plug wire was not affixed securely to plug. All is good now.
**** I forgot how speedy that little car is!
David.R53
Sep 1, 2015 06:49 PM
Aug 21, 2015 10:07 AM
finn
Aug 21, 2015 07:59 AM
truedrew
R60/R61 Stock Problems/Issues
Aug 10, 2015 10:39 AM
