JCW JCW Strut Brace?
I have it. Looks nice. Not aware of any cons. I couldn't tell you whether it makes a difference in handling, or not. Seemed like a good idea when I ordered the MCS. Installed it shortly after receiving the car.
I have it...looks sweet, fits fine with my Alta intake...couldn't comment on handling difference cause it was installed before I picked my car up. But it will stiffen the front end of the chassis, maintain the front suspension geometry, especially on bumpy roads.
$275.00 when I ordered my MCS. Installed it myself. It required a little metal work as there was an error in which bolts were being used on the car.
I've searched far and wide. There is no other option yet although DDM has pics of a prototype which they refer to as 'ready for production' in their CAI thread. I suspect M7 will have one soon. These other brands will most likely be cheaper than the JCW and have the added benefit of integrated strut brace plates that will help prevent the mushrooming problem that many people are experiencing.
I had mine installed...
...with the JCW kit and I felt a little improvement in the way the car corners under acceleration.
I haven't had any mushrooming problems, I think the extra material helps with reinforcing that area.
I would have like a better price from the dealer but wanted to keep with Mini parts.
I'll probably go with the M7 option, although I wonder how many people with R56's are having mushrooming problems. Most of the reports I've read have been from the first generation crowd, and it would make sense that MINI (at least partially) addressed this issue with the R56.
This is just speculation, and I'm likely to go the M7 route unless I really think the problem has been fixed.
That sure is purdy Scott
So looking at the pic you have is there any sort of clearance or fitting issue with the Alta CAI?
Also did you notice any improvments with tighter chassis or suspension?
No clearance issue with the Alta intake....and my car came with strut brace from the start, so I couldn't say how much of a handling difference it made.
So I've heard people say the JCW strut brace doesn't fit w/ the JCW airbox, yet others say they have both with no clearance issues. Who is right??? I drive over some nasty (unavoidable) bumps on a daily basis and am afraid of mushrooming. The improved rigidity would be an added bonus. I do plan on getting the JCW Stage 1 in the spring, so I would like to know if any strut braces fit with it.
