Interior/Exterior Rally Light bar with an R56?
Old Aug 30, 2007 | 06:31 AM
  #26
OutMotoring's Avatar
OutMotoring
Vendor - 15 Years
Originally Posted by Arnbut
Hmmmm.
Could you put two big yellow ones on in addition to these:
yes, with our new brackets, you could put at least 2 maybe 4 on the front along with the two you have....
Old Aug 30, 2007 | 06:44 AM
  #27
Salty's Avatar
Salty
it looks good and it's something I've wanted, but it doesn't appear to be compatible with any kind of front license plate...
Old Aug 30, 2007 | 07:34 AM
  #28
oldopelguy's Avatar
oldopelguy
bingo
Also a problem for me. Can they be spread apart to be two groups of two, with room for a plate in the middle?
Old Aug 30, 2007 | 07:44 AM
  #29
ahalibut's Avatar
ahalibut
Don't tell anybody, but one of my big motivations for hopping state lines when I was looking for an apartment from Missouri to Kansas was to not need a front license plate.
Old Aug 30, 2007 | 09:24 AM
  #30
Arnbut's Avatar
Arnbut
As long as you're making dreams come true, make it a pair of yellow Hellas in the middle wired to the missing bottom toggle (rear fogs that I don't have).
You could install the missing toggle, couldn't you?
When's your next rally for doing installs down here? My wife has an R53 and we met you at MOTD-06 ---- I could see her wanting a set of lights maybe too...
Old Aug 30, 2007 | 09:27 AM
  #31
OutMotoring
Vendor - 15 Years
the extra switch deal is tricky but there have been a few that have done it on the R53...do a search and see if you can find the threads...
We will be at the Dragon in 08' and I am sure Helix or Detroit Tuned will be able to do some installs of the brackets down there......
Old Aug 30, 2007 | 09:30 AM
  #32
OutMotoring
Vendor - 15 Years
you can mount them in a variety of locations that are mostly limited by how much of the grill and/or snaps you want to remove to allow the brackets to protrude. There are a few ideal locations that have less interference from the snaps and such and on my car I was able to get 4 large Hella 1000's mounted across the front without issues so I am sure you can mount just two and get a plate in the middle....or 4 and hang the plate from the mounts. In that case you would be restricting air flow to the intercooler.
I just have my plate on the passenger side dash right up against the glass...
Old Aug 30, 2007 | 09:31 AM
  #33
Arnbut's Avatar
Arnbut
Or Way or Harrison's (which is only 2 miles from my office...).
I know! I'm going on vacation out west next Saturday. The timing is perfect for an OutMotoring beta test of the light bar and Hellas ----- I could detour through Ohio, have you install the product, and blog the experience with photos.... ....maybe a free install for the detour.....
Old Aug 30, 2007 | 11:00 AM
  #34
dlroto's Avatar
dlroto
just keep us posted
Old Sep 12, 2007 | 09:50 AM
  #35
Chiky's Avatar
Chiky
good morning.. any news on the light bars?
Old Sep 13, 2007 | 08:33 AM
  #36
OutMotoring
Vendor - 15 Years
they will be delivered monday and I will do a test install to confirm everything fits as it should and make them active on the site.
Old Sep 13, 2007 | 10:34 AM
  #37
dlroto's Avatar
dlroto
I'm in one of the states where you have to have a front plate so I have to wait to see how that works out with the rally light bar.
Old Sep 13, 2007 | 11:14 AM
  #38
nicknbecka's Avatar
nicknbecka
Washington State is the same- my plan is try to find a successful combination of a tow-hook mounted license plate, higher rally light mounting, and a bit of ingenious modification.
It'll be a few months for me to save up for the aero-kit and lights though, so if you figure it out in the meantime, I won't mind
Old Sep 14, 2007 | 12:03 AM
  #39
dlroto's Avatar
dlroto
I still haven't gotten a mini yet, I'm looking for ideas for my girlfriends R56, They just increased the prices for the 08's what a bummer.
Old Sep 17, 2007 | 12:47 PM
  #40
ice877's Avatar
ice877
let us know how the fit went if you got the chance today or if they came in!
Old Sep 17, 2007 | 01:07 PM
  #41
OutMotoring
Vendor - 15 Years
They're in my hands but I need to test fit tomorrow night...
Old Sep 18, 2007 | 06:45 PM
  #42
OutMotoring
Vendor - 15 Years
all is well:
http://www.outmotoring.com/mini-coop..._brackets.html
Old Sep 18, 2007 | 06:57 PM
  #43
OutMotoring
Vendor - 15 Years
Just to clarify, these are individual brackets that are sold in sets of two (2) that can be mounted in a few select postions in front of the bumper on the Gen 2 MINI. Up to 4 brackets (2 sets) can be mounted across the front. One of the limitations for the locations is the tabs that hold the lower grill to the actual bumper. Because some of the plastic grill must be removed to allow the brackets to protrude it would be wise to leave some of the tabs on the top edge of the grill functioning. Mounting 1 set of brackets will have minimal affect on the grills stability but 4 can be mounted as long as care is taken to place the brackets between the plastic tabs.....
Here is a how to:
http://picasaweb.google.com/OutMotor...DLightBrackets
Old Sep 18, 2007 | 11:00 PM
  #44
nicknbecka's Avatar
nicknbecka
Thanks Aaron, I notice that there's a front plate adapter in the works too. Can you share any info on how that fits?
Old Sep 19, 2007 | 12:38 AM
  #45
YseanY's Avatar
YseanY
Here is a how to:
is it possible to maybe include a DIY or picture of which tabs to remove for those who would like to have 4 lights evenly across?
also, maybe a kit to include lights, brakets, wiring, and oem switch?
Old Sep 19, 2007 | 06:26 AM
  #46
OutMotoring
Vendor - 15 Years
The adapter will use the bolt from whichever lights used to hold a second bracket that will overlap the bracket a bit and have a bend in it to allow the plate to be mounted/'hung' below the light bracket.
Old Sep 19, 2007 | 06:28 AM
  #47
OutMotoring
Vendor - 15 Years
this picture shows the exact position of the slots to allow for 4 lights to be mounted equally spaced. I can take some measurements if that helps but if you look closely you can see where those inner two slots are in relation to the nearest tabs.
http://picasaweb.google.com/OutMotor...28486527519890
The oem switch is proprietary to their wiring harness's and is actually a replacement of part of the dash which runs anywhere from 70-110 which is pretty high...and regarding lights, we have the Hella 500 Driving, 500 Fog, Amber Fog, Hella Black Magic, Piaa 540 and Piaa 520's on the site and all of them come with wiring and switches, etc...so I will most likely not lock into one light for the kit...
Old Oct 1, 2007 | 04:36 PM
  #48
Rubino's Avatar
Rubino
Aaron??
Any updates on the Availability of the Quad-Light-Bar for the R56?
My front end is feeling a bit "nekid" and just a little bit dark?
Let me be among the first to get one installed.
Old Oct 2, 2007 | 05:47 AM
  #49
OutMotoring
Vendor - 15 Years
Yes, they have been available for 3 weeks now on the site:
https://www.outmotoring.com/mini-coo..._brackets.html
Old Nov 12, 2007 | 12:40 PM
  #50
R56MINICooper's Avatar
R56MINICooper
Although you have a bar available it does not look like it would work with a standard Cooper that has a front license plate. I emailed about a month or so ago about this to see if you had any other brackets for the R56 Cooper but haven't gotten a response. Any chance you have another bracket that works with the Cooper with with a front license plate? Thanks!
