Interior/Exterior oil gauges
Old Mar 12, 2007 | 07:48 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
oil gauges
Does anyone know how to install these oil gauges? I havent bought any yet.
oil temp
oil pressure
I was going to get the gauge pod that sits below the toggle switches.
Old Mar 12, 2007 | 08:21 PM
kyriian's Avatar
kyriian
two options
one is have a shop make an adaptor so that it fits into the oil cooler
two is to tap the top of the oil filter housing, and use teflon tape to ensure no leaks.... i believe my mechanic uses some sealant in there as well, we did it this way, and so far no problems,
one last option also is the madness oil cooler plate, which has two fittings made for gauges... which is what i want now
Old Mar 12, 2007 | 08:27 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
What about electrical connections? Is there some master control unit needed? As far as taping, I think I can tap the oil cooler adapter oplate. The holes for the stock exchanger are oval, and the oil plates holes are round so there is a spot I could drill. Does the oil pressure gauge need any special placing?
Old Mar 12, 2007 | 08:36 PM
mcnamaraz's Avatar
mcnamaraz
For oil temp, you can get a lug that replaces the factory oil drain plug. The new plug will allow you to use the temp sensor that comes with the gauge you purchase by threading this sensor into the plug....with teflon tape of course.
This is one I bought and its been working just fine for about 2 weeks. No leaks.
http://www.42draftdesigns.com/product/sw/42908.htm
maniacalmorgan
38
Sep 29, 2015 04:56 AM
Tylerlanger1
Aug 21, 2015 03:03 PM
finn
Aug 21, 2015 07:59 AM
dchang0
Aug 10, 2015 03:37 PM
