Interior/Exterior 2006 - Advice on removing trim above steering wheel?
Old Mar 10, 2007 | 12:03 PM
MiniSuperCooper's Avatar
MiniSuperCooper
The trim piece above the steering wheel doesn't want to budge. I've even gotten the center piece to break lose, but I can't fully remove it until I get the driver's side off. There seems to be two clips on the bottom, and they've been popped out. There are two more on top of the trim that will not move. I've tried wiggling it back and forth. I think I'm just about wiggled out. I sure hope all this goes back on as easy as it comes off.
Old Mar 10, 2007 | 06:06 PM
ImagoX's Avatar
ImagoX
When I did mine I got the center peice out and in by just freeing the bottom clips on the driver's side then wiggling free the center panel. Remember that the center peice has two screws (next to the hazard and light dimmer buttons) that screw upwards into the bottom edge of the dash...
Old Mar 11, 2007 | 11:54 AM
MiniSuperCooper
Thank you Matt. Yep...I found the screws on the center piece. I'm beginning to wonder if there's a screw or something that I'm missing on the driver's panel. So very confused...
Dec 23, 2015 10:36 AM
Bennyboy
Aug 18, 2015 07:28 AM
nomar116
Aug 12, 2015 05:24 PM
MES11
Navigation and Audio
Aug 6, 2015 08:52 AM
