Interior/Exterior Any idea how to remove washer jets cover?
Old Mar 1, 2007 | 09:52 AM
vodka's Avatar
vodka
Hi all,
Anyone know how to remove the washer jets cover? How about the front bonnet MINI logo? Just use floss to cut the double sided tape than pull it out? Easy? So that I can stick the bonnet stripes without pre-cutting a hole (if possible)... Any ideas?
Thank you very much
Old Mar 1, 2007 | 09:55 AM
GBMINI's Avatar
GBMINI
That's a whole washer jet to be removed, not just the cover. It's a single assembly.
They have a plastic latch that clips from under the bonnet.
You need to open the bonnet, and undo the insulation pads fixed to it so that you can see the underside of the jets - then you'll see the clip you need to squeeze, to release the jet from above.
No idea about the logo, maybe a bit of heat to soften, then floss as you suggest.
Old Mar 1, 2007 | 11:38 AM
mdsbrain's Avatar
mdsbrain
Jets - Push them towards the windsheild. They will move and bit and then be able to drop into the bonnet so you can install the vinyl.
Old Mar 1, 2007 | 04:17 PM
GBMINI's Avatar
GBMINI
Really Mark! Wow, didn't realize that - I thought it was an access from below thing ...
OK, vodka, ignore my post
Old Mar 1, 2007 | 06:06 PM
vodka's Avatar
vodka
Thanks guys... will try, hope I wont break anything :D
Old Mar 1, 2007 | 06:49 PM
MiniMaybee's Avatar
MiniMaybee
I usually pop them off when detailing. Just a small screwdriver on top of my finger and slightly under the edge and then pop up!
womble
Classic Mini Talk
Aug 24, 2015 12:52 PM
Powershift
Aug 16, 2015 05:14 PM
minipopkart
Aug 13, 2015 05:22 AM
ludedude
Aug 10, 2015 07:16 PM
