Interior/Exterior AfterMarket Steering Wheel
Old Dec 27, 2006 | 08:51 AM
Jtrem's Avatar
Jtrem
Does anyone have an aftermarket racing steering wheel installed on there mini?
Old Dec 27, 2006 | 10:15 AM
skitelluride531's Avatar
skitelluride531
Wouldn't you loose your airbag? Seems kind of silly for a daily driver car. To each their own I guess...
Old Dec 27, 2006 | 11:12 AM
UKSUV's Avatar
UKSUV
What do you wanna know? You might what to ask a more specific question. You know better than that.
Old Dec 27, 2006 | 01:43 PM
onasled's Avatar
onasled
There are a few. Randy from M7 has one. He is away from home right now, but if you do a search you might find some threads about it, and others
Old Dec 27, 2006 | 01:45 PM
Motor On's Avatar
Motor On
https://www.northamericanmotoring.co...highlight=show
Old Dec 27, 2006 | 04:31 PM
Jtrem's Avatar
Jtrem
I think it would be a pain to remove the steering wheel and put an aftermarket one. I dont care about losing the airbag Im going with a harness set-up anyways. Its not a daily driver anyways. I have a truck my work provides me.
Old Dec 27, 2006 | 05:41 PM
kenchan's Avatar
kenchan
^^ pain? really? not sure, but ive done steering wheels in the past
on my other cars and it's really straight forward. the only thing is if
you can get a hold of the hub with plug and play harnesses (usually
only available in Japan) it makes the work so much easier as you wont
have a SRS DTC light (you can make your own trick resistor), and
you will not loose your wirecoil thingie inside the steering wheel for
the horn. otherwise you have to make a wire that twists inside
there which works but kind of a ghetto setup imho.
see if www.japanparts.com can get you a steering wheel boss (hub)
with the plug and play. they can pretty much get anything that's
available in Japan even if not listed at their site.
woodstudio
Mar 15, 2020 08:28 AM
mickymow
Jan 25, 2016 01:54 AM
trw92a
Aug 26, 2015 01:47 PM
MES11
Navigation and Audio
Aug 6, 2015 08:52 AM
