Interior/Exterior Help! tail light assembly removal how-to?
I'm trying to remove my tail light assembiles but can't seem to get them out. There is one bolt and 2 clips. It's clear that you remove the bolt but how the heck to you get those clips out of the way? They are pretty firm and it seems that you need to release them at the same time...anyway, what's the "trick" to getting those clips off?
Any help would be appreciated. I've searched and couldn't find out how. I've seen a couple of references to "remove the clips and ..." but I must be a dork since I can't get those clips off...
Thanks!
Thanks!
There are two clips on the outside of the unit. Press in (towards the inside of the car) and the whole thing should pop out (assuming you removed the bolt). The bottom clip can be a bit difficult to get to with larger hands. Try the top first and it should become more obvious.
Putting them back in is easy as all you have to do is line it up with the bolt and tighten. The clips will fasten themselves once it gets tight.
>>Thanks!
>>Thanks!
That's exactly what I tried...maybe my clips are really stiff, but I can't seem to bend them far enough to unclip.
So...should I be able to depress the clip, pop the top loose, and then proceed to the bottom one? Maybe the rubber gasket is tight and I didn't push out hard enough. I have another set of tail lights and those clips are way stiff as well...
Sound like I just need to try harder....hmmm...
cm.d
Aug 19, 2015 08:51 AM
