Interior/Exterior Parcel Shelf - no hardware! Aftermarket?
Old Oct 20, 2006 | 01:36 PM
bloodyank's Avatar
bloodyank
I ordered my parcel shelf from morristown MINI and it came alright, but I've got no hardware. Anybody got the specs so that I could just grab the screws and the receiver clips at an O'Reily's or somewhere? The nearest MINI dealer is three hours away.
Old Oct 20, 2006 | 02:00 PM
terryg's Avatar
terryg
The supplied clips are horrible. Anything you find has got to be better :-)
I was about 5 seconds away from just using a bolt and wingnut this week after fighting with the left side screw on two different shelf installs.
Once you remove the knee bolster, you may find that you have something floating around tha garage (or nearby hardware store) that'll work.
Good luck on the install !
Old Oct 20, 2006 | 02:14 PM
iflymini's Avatar
iflymini
I got one from MOSS also....I found some hardware on the bottom amongst the paper filler. It was a small plastic bagg.
iflyMINI
Old Oct 20, 2006 | 02:29 PM
AntiqueCarNut's Avatar
AntiqueCarNut
Try a local hardware or auto supply store. Pick up a couple of #6 or #8 fold-over speed nut clips, like these and a few #6 or #8 black trim screws, maybe 3/4" to 1" long, like these.
My shelf was also missing the hardware and I improvised with hardware bits similar to above.
Old Oct 20, 2006 | 03:11 PM
FUEGO's Avatar
FUEGO
I eventually replaced the crappy blue plastic clips with the speed nut clips. I found them at Lowes in the specialty hardware drawers in the hardware/fastener aisle but you should be able to get them at nearly any car parts store. The #6 was the perfect size for the screws supplied with the parcel shelf. They worked so well I also replaced the same blue clips that hold both downtubes in place (2/tube).
Filmy
15
Jun 6, 2023 06:27 AM
Nicefeet
Oct 1, 2015 05:08 PM
sempaipaul
Sep 18, 2015 03:05 PM
Sep 14, 2015 12:48 PM
Accessory Products
Sep 9, 2015 10:29 AM
