Interior/Exterior How can I quiet squeaky brakes?
Old Aug 15, 2006 | 01:37 PM
RonP's Avatar
RonP
At slow speeds my brakes squeek, loud. Any way to quiet them without swapping out to new pads? My pads have a long way to go before needing replaced.
Old Aug 15, 2006 | 01:40 PM
dazite's Avatar
dazite
When that was happening to mine, my lovely husband took them off and ruffed them up on the cement and it stopped...whether or not that is a good idea, I dont know. But it worked!
Old Aug 15, 2006 | 02:13 PM
sandtoast500's Avatar
sandtoast500
You probably have a glaze on them from light use. Go rip down a canyon and use them hard, or just fly off some off ramps at at least 60, then slam the brakes, not to the point of abs kicking in though. . .
Do that a few times and they should be brand new.
Roughing them up works too, but it's not even wear.
Good Luck-
-Steve
Old Aug 15, 2006 | 02:14 PM
qwertmonkey's Avatar
qwertmonkey
Rubbing them on cement may not be the best idea. When the brakes on my Landrover Discovery started to squeek really bad, I took off the wheels and brake and gave it a DEEP cleaning. The dealer said it could have been dust build up. I'd try cleaning them off before rubbing them on the driveway.
Old Aug 15, 2006 | 02:23 PM
RonP's Avatar
RonP
Thanks guys. I'll give them a few hard stops on my way into work shortly and see if that helps.
Old Aug 15, 2006 | 02:46 PM
MadHatter's Avatar
MadHatter
probably gonna get flame-ed for this one...
But 20 years ago, I would sprinkly a 1/4 teaspoon of ajax cleaner directly in the pad area and that would remove the film that builds up and causes the noise...
You take full responsibility if you do this - have no clue if this is good, bad, whatever with respect to BMW and the MINI.... plus the dealers will probably JUMP to deny warranty status just for fun if they can have an excuse.
Old Aug 16, 2006 | 11:10 AM
RonP's Avatar
RonP
Hitting the brakes semi-hard seems to have quieted them down by about 50%, so, I need to hit them a little harder and hopefully that does the trick.
Old Aug 16, 2006 | 11:12 AM
sandtoast500
Nice.
3-4 offramp stops should do it.
Good luck-
Old Aug 16, 2006 | 11:34 AM
ImagoX's Avatar
ImagoX
Originally Posted by sandtoast500
Nice.
Good luck-
That always worked on my motorcycles... bike breaks squeal worse than car brakes for some reason, and hard braking always seemed to "de-glaze" them (or whatever it does), making them run quiet again. Of course, if you just drive like a maniac ALL THE TIME then it won't return now, will it?
Colt45Magnus
Sep 14, 2015 03:12 AM
Sep 10, 2015 10:52 AM
Tinklespout
16
Sep 6, 2015 11:39 AM
Sep 4, 2015 09:23 AM
PelicanParts.com
Tires, Wheels & Brakes
Sep 3, 2015 03:22 PM
