Interior/Exterior Instructions to Remove rear bumper cover
Old Aug 5, 2006 | 09:22 AM
mistro's Avatar
mistro
Anyplace on this or some other site to learn how to do this on an 05MCSC? TIA Michael
Old Aug 5, 2006 | 10:36 AM
mini-rolls's Avatar
mini-rolls
Rear bumper removal is easy, is best done if you remove the wheel liners. It allows you to see the attachement points better. Just look for the screws holding it on. Also, with the whell wells out you may want to try spraying undercoating inside to help with road noise. I did this when I put on the cooper mudflaps and it really helped. The mudflaps helped with the rear dirt also.
Old Aug 5, 2006 | 01:42 PM
XAlfa's Avatar
XAlfa
Try this.
Old Aug 6, 2006 | 07:07 PM
1FSTMINI's Avatar
1FSTMINI
Removing and installing rear bumper trim
The following work operation applies to all MINI variants
Remove both rear wheels
Remove rear left and right wheel arch flares
Remove reversing light
Remove screws (1) from cover for spare wheel recess (depending on equipment).
Remove threaded blind rivets (2) on both sides.
Remove screw (1) in opening for reversing light
Remove screws (2)
Disconnect PDC plug connectors (1) (depending equipment).
Disconnect plug connectors for side marker lamps (depending on equipment)
Remove bumper.
Old Aug 6, 2006 | 07:25 PM
mistro's Avatar
mistro
thanks both mini-rolls and 1fstmini
Old Aug 6, 2006 | 07:49 PM
1FSTMINI's Avatar
1FSTMINI
No problem
Mini'mon
Aug 26, 2015 01:02 PM
skippermini
Aug 12, 2015 10:05 PM
ludedude
Aug 10, 2015 07:16 PM
bctf1
Aug 6, 2015 12:55 PM
