Interior/Exterior Blacked out grill. I don't know......
Well, I did make a few calls and found some vinly places that have blackout tape in widths as wide as *5 feet* (what possibly could you use that for?)... the problem is that they want about $12 a FOOT for the 24" stuff.
Where did you find it for so cheap, Moreorless?
Originally Posted by ImagoX
Hey Moreorless... can you provide some sort of stock number or a brand name or something for the sheet of vinyl you bought? I've looked all over for "black automotive vinyl 24'" and various combos thereof and all I'm getting is like pinstriping tape.
If you used what I THINK you used then I think I might actually attempt this as my first MOD... Well, OK, my second- I'm putting in an AUX port for my MP3 player this weekend. I know, I know, laaame, but you gotta start someplace, right?
If you used what I THINK you used then I think I might actually attempt this as my first MOD... Well, OK, my second- I'm putting in an AUX port for my MP3 player this weekend. I know, I know, laaame, but you gotta start someplace, right?1. Clean off all the wax on the parts that will get taped.
2. Use a straight edge and cut your strips at about 1" 3/4 wide.
3. Get a spray bottle fill it with water and put in a drop or two of dishwashing detergent and shake it real good.
4. Spray a light mist of your first slat.
5. Tuck your tape up close to the end and have at it.
Keep a micro fiber rag handy to wipe off the tape and push out any air bubbles. The tape will stretch as well.
Post pics when you're done!
....Les
Originally Posted by moreorless
Ok, so I blacked out my grill with the usual satin black automotive graphics vinyl.....
But I'm not really sold on it. Yet.
What do you SME's think?
...Les
...Les
I installed mine this weekend... the vinyl is a real PITA to work with, and took some trial and error - I'm VERY happy that I cut a few extra strips before beginning the install. Also, be sure to give yourself at least *2 hours* of solid daylight before beginning this if you've never instaled this before - it takes some trial and error and believe me, running out of light makes things MUCH harder (don't ask me how I know that).
Some tips I found out as I was going:
1. 1 3/4" strips were too wide for me. 1 3/8" was actually about perfect - wide enough to have some extra to tuck aruond but not TOO wide. I used 36" wide material and that gave me a few extra inches to work with at the end of the strip.
2. I began by cutting the end of the strip at an angle to match the side of the grille BEFORE peeling away the backing material. Each grille slat (there are 4, 3 on the upper, 1 on the lower) has unique angles where the grille slat meets the edging peice. Take your time and keep cutting until the angle is just right. Don't rush - the backing is still on the vinyl so you can afford to go slow.
3. After the beginning angle was cut with scissors, I peeled away the backing and applied. Be sure to only apply a GENTLE MIST OF WATER - if you use too much, the strip will slide around forever and will take a long time to adhere. The more it slides around, the greater the chance for folds or bubbles. I found it was better to use too little and have to mist a second, gentle spritz than saturate the grille with water. Again, having EXTRA STRIPS makes this less stressful, as if you screw one up (fold or crease it, bubble it, etc.) you can just pull it off and try again.
4. Have an exacto knife with a BRAND NEW blade handy. You'll need it to trim around the verticle supports that back the grille slats (just make a single verticle cut on each side of each upright "post" and press the material back around it) as well as to trim of any extra material that you end up with. ONLY a new blade will cut the surprisingly tough vinyl cleanly without tearing.
5. When you reach the far end of the grille slat, trim off the excess with scissors. Be sure to cut the strip 2" or 3" longer than you think you need at first, lest you undercut. If you undercut by accident, pull it off and start again (no, you can't stretch it to fit). I found that if I pressed the vinyl into the edge of the grille (where the slat mets the siding), that it "creased" the vinyl a bit and showed me where to make my last scissor cut. I'll say it again - CUT LONGER THAN YOU THINK YOU NEED, even with the fold mark as a guide. Better to have to trim an extra 1/8" or be a bit over (which won't show to the eye) than be that ammount short and have the grille showing at the edges (whicb certainly will show like a beacon).
6. After getting out all the visible air bubbles with your squeegee, wipe away the extra moisture and WALK AWAY for 30 minutes. Resist the urge to futz wth it, as you will just end up sliding it around and getting bubbles.
7. After 30 minutes, most of the glue should be stuck down. Be sure to smooth all edges around the back sides of the grille slats, opening the bonnet to assist you in seeing everything. if you have any bubbles, try gently smoothing them out but don't pop them yet if they won't stick - about half of mine went away by themselves when I parked in the sun for a few hours. Any that don't go away can be popped with a sewing needle or other SMALL pin. DO NOT use your Exacto knife to pop bubbles.
8. The next day, you can hit the vinyl with a bit of dressing (whatever vinyl protectant you use on your trim) to make them look great!
Pics:
BEFORE:
AFTER:
Pics:
BEFORE:
AFTER:
Thanks for saying so. I think it accents the "bulldog" stance of the car better than even the body color-painted grille. It's a cheap MOD that's a bit challenging, and is easily reversable if you later change your mind, which in my mind makes it great.
I think the black roof and wheels helps tie-in the scoop on your car, Agro... it certainly looks better with the scoop next to the black grille, compared to the version in your sig image, IMHO - nice! I don't usually like them, but you may want to consider the blacked-out headlight rings with your car as well - just a thought. Most of the time I think the OEM chrome looked better when I saw that MOD on other cars, but in your case it might look really fitting... the smoked headlight film might look good with that black and yellow theme as well (though I'm sure you already considered that).
ImagoX nice work and great write up. I just laid my vinyl on the grill and gut slits and wrapped it like that..I prolly could have done a better job after reading this, but it was my first big vinyl project. I think tonight I am doing the headlight rims I will post pics later.
Does anyone know what the law is in TX about blacked out headlights (smoked out etc) I would really like to do that too in my anti chrome battle hehe.
~R
~R
I thikn the blackened out look looks fantastic.
The black grills draws your eyes else where and highlights the surrounding areas.
The chromegrill i felt was always to busy in the center of the front end.
Alice would never get a black eye. Yeah, I need to update the image in my sig. Even the one in that picture isn't completely current. I now have yellow mirror caps and black and yellow center caps on the wheels.
Let me bounce this off you guys....
I found a packaged product called simply black out tape. It is flat black and says on the package it is used for chrome belt lines etc on cars. It's 2" wide and comes in 20' rolls. they were 3.99 a package so I bought two rolls.
It was in an autozone by the house. I didn't inspect the material yet but it looks thicker than say electric tape but that may be because of the backing.
Here is my question, I would like to cover the chrome accent ring around the slats as well. I have a pure silver/black roof with twin viper stripes running the middel of the car. How hard is it to also do the chrome? anybody done it ?
Can you let me know the brand and item# of that tape? 2" is certainly wide enough, and 20' would do about 2-3 grilles. When I looked for tape like this, I couln't find it that wide, and that's why I cut my strips ut of a single sheet. the best price I've found so far for a hunk of sign vinyl large enough to do 2 grilles is $16, though.
Thanks!
But the aero grills are still the nicest front grill mod IMO.
i'll try the slats first and if I am rolling without any hiccups I will continue.
The rolls are in the back of my Cooper. I will post once I bring them into the house. Thanks for the feedback and I'll post pics if it comes out decent LOL.
