Interior/Exterior Powder vs Paint
Old May 5, 2006 | 11:27 AM
Pebblecrusher's Avatar
Pebblecrusher
Powder vs Paint
Has anyone thought about powder coating the entire MINI? Rumor or myth or fact I am not sure, but I've heard powder coating is a bit more chip/scratch resistant.
Considering some of the prices I have seen people post about powder coating smaller items, such as gas caps, the price to coat an entire vehicle should be about what you would pay for a good paint job.
Old May 5, 2006 | 12:29 PM
Rally@StanceDesign's Avatar
Rally@StanceDesign
it would cost so much more to take apart the car and clean up every part (inside and out)....(and that's if it's even possible)
You would also need to find a company that had big enough 'tubs' that could fit the big parts like the hood and the bonnet. and the bumpers would still need to be painted as they aren't metal.
Old May 5, 2006 | 01:25 PM
Pebblecrusher
From what I have read, dipping is not the only way to powder coat. Though it may be the best as far as coverage goes. And it is possible to powder coat some plastic. You just have to make sure the powder is the lower temperature stuff.
Old May 5, 2006 | 01:46 PM
T-diggie's Avatar
T-diggie
Why not just 'Rhino line' you entire car?
Old May 5, 2006 | 01:47 PM
Rally@StanceDesign
You are right...i just found an article about coating plastics and EVEN wood
Old May 5, 2006 | 07:14 PM
Rawhyde's Avatar
Rawhyde
Powder coating does not make a smooth finish. It'd look worse than a $89 Maaco job. It looks ok on smaller parts where the "orange peel" isn't so obvious.
Old May 8, 2006 | 07:09 AM
Pebblecrusher
From what I've been reading, the orange peel isn't so obvious anymore. Especially with the newer technologies. Stay away from epoxy powder coating. It's not for outdoor stuff. The articles I read mentioned TGIC as the choice for outdoor stuff.
Old May 8, 2006 | 08:17 AM
MGCMAN's Avatar
MGCMAN
I had my EX powder-coated. Best money I ever spent!
Old May 8, 2006 | 08:20 AM
Pebblecrusher
EX as in EX-Wife? What did you do.... Hang her on the wall like a trophy?
Actually I am not familiar with the EX...
Old May 8, 2006 | 10:00 AM
omascow's Avatar
omascow
Spray On
If you want to change your MINI to black then you could buy a case of this stuff and coat your entire car! http://www.griotsgarage.com/catalog....1090&SKU=20264
Old May 8, 2006 | 10:58 AM
pdflint's Avatar
pdflint
One big hurdle to overcome with powder coating (besides the high levels of cleaning required) is that you have to bake the finish in order to cure it. Powder will not "air dry" like most liquid paints if it does not bake at the required metal temperature for the minimum time required. Typical times are 30 minutes at 350 F. Some parts may not be able to withstand those temperatures without distorting.
You need to find someone with an industrial oven capable of reaching 375 F - 450 F that is large enough to hold the parts you are coating.
Gloss, orange peel and film thickness will also differ from liquid coated parts.
Also, you would most likely need to completely strip the old finish as the bake temperatures required would damage or destroy any liquid coating remaing on the part.
Old May 8, 2006 | 11:02 AM
MGCMAN's Avatar
MGCMAN
Why yes,very perceptive. No more problems after that application.
bahman
Feb 14, 2016 10:29 AM
jeri534
Nov 6, 2015 01:40 PM
vulkandino
Oct 31, 2015 08:29 PM
BackcountrySkier13_inAZ
Oct 14, 2015 06:00 PM
M7Speed
Oct 1, 2015 07:05 AM
