Interior/Exterior Factory method for mounting a front license plate to an MCS?
I picked up my MCS yesterday. The MA asked if I was planning on running with a front plate. CA requires it, but can't pull you over for it. 90% of the time you get a fix-it ticket -- no fine, but you have to prove you've fixed the problem in 30 days.
I'm getting a vanity plate and unlike my Miata, it doesn't totally hose up the front end of the MINI.
So I asked if it was something that I could do on my own or if there was any reason I should have the dealer do it. He mumbled something about parts and tools and said that it's "better" for them to do it and there was no charge. So I let them go ahead.
Today I go check it out and it's a black piece of plastic that is NOT a MINI part and it's mounted to the bumper via two screws directly into the fascia.
Does MINI not have a factory way, one that doesn't involve butchering the plastic, to do this? I'm guessing I'm stuck now and I should not obsess about if it's exactly square and level. But don't they have a better solution than this?
(I'd say that German auto engineers know better, but they had a similar solution for our 2002 Passat which is why I have an unadulterated bumper on that car.)
Sorry to tell you, but that IS the factory way. I got a black plastic mount with my car. It clips onto one of the grille slats and has to be screwed into the bumper to keep it in place. It sits in my boot next to the battery.
The front bumper actually has a couple of dimples where the screws are supposed to go in.
I don't think I've seen any Sin City MINI Club MCSs with front plates attached.
Weak.
Like I said, I was planning on running a plate, so I guess it's not horrible. But given how well the rest of the car is designed & implemented, I'm surprised that this is the official solution. WEAK.
I thought of the tow-hook idea, but I hate assymmetry almost as much as I hate poor engineering.
So I guess I'll go with the Europlate until Ponch and John complain, then I'll restore the crappy solution.
I wasn't about to punch holes in my car when I moved to Ohio. Instead, I took the black plastic MINI provided plate bracket and used the clips as you mentioned to secure it to the bumper. But as reinforcement, I also affixed two metal wire loops (like picture hanging metal wire) that go through the plastic mesh under the bumper and I drilled to small holes in the plastic of the bracket to complete the loop. I also used velcro tape on the bumper and the back of the bracket. Even if the license bracket slips out of the slat, the wire loops will hold it in until I see it and snap it back in. It falls off every couple of months or so if I maybe hit it walking by in the garage and don't secure it properly. I highly recommend it. NO HOLES!
Originally Posted by The MINITOR
I'm not one for assymetry either, but I'm not punchin any holes either so I compromised and I like it:
Garret that design looks oddly familiar. Just giving you crap. Because I can
Garrett
sweet
Originally Posted by mini-rolls
Originally Posted by makmini
That is pretty nice - any place to get this cheaper? $50 seems kinda steep to me...
Can not get the machined bolt any cheaper.
Also, the stock license plate holder the dealer installs costs $80.00. I looked into that and then you have to drill the front of the MINI.
One other point for me was that the price of a ticket in WA for no front license plate is $101.00 so this bracket is half of that so I figure I saved.
I know the bolt had to custom made so that is why the price is where it is.
The $50 for the gominigo set-up doesn't seem so expensive if you take into account the time it would take to go buy the hardware and then cobble it together
