Interior/Exterior Back seat side window shades
Old Dec 31, 2005 | 02:04 PM
SoCar S's Avatar
SoCar S
Saw some factory back set clip-in window shades.... Did a search.... can't find them. Any one know the thread? or have the part numbers?
Thanks in advance.
Old Dec 31, 2005 | 03:48 PM
MiniBetterThanBeer's Avatar
MiniBetterThanBeer
Thanks in advance.
Here's the part number: 51460142578 from realoem.com
They come with velcro but you won't need them since they spring into place between the b and c pillars.
You can find them on eBay but I'm not sure if they're available elsewhere for less than what your dealer would charge. Just be forewarned that the ones on eBay may be old stock since catalogue pictures show a slight difference in design.
Here's what's different: The eBay shades have a little gap in the rear upper corners. It isn't very noticable from the outside but they seem like manufacturing defects. The (presumably) newer ones have a squarish cut-out in the same rear upper corners which leads me to believe that the gap is necessary for some reason and that the square cut-out was a design revision meant to avoid looking like a defect.
Old Dec 31, 2005 | 05:25 PM
NMgokart's Avatar
NMgokart
Is this what you are looking for?
http://www.myminiparts.com/proddetai...rod=MSS&cat=10
Old Dec 31, 2005 | 05:50 PM
LordOfTheFlies's Avatar
LordOfTheFlies
I have the eBay ones. I used a sewing pick (don't know what it's called) and removed the sewn in velcro tabs because MBTB stated, it just snaps right in between the two pillars.
Much better visibility compared to my 5% tints I had there previously. Still have the 5% in the back though.....
surfblue
Oct 24, 2018 01:20 AM
steelz21
Sep 12, 2015 10:06 PM
minicoclub
Aug 25, 2015 09:07 AM
cm.d
Aug 19, 2015 08:51 AM
