Interior/Exterior Door Handle Removal (Outside)
Old Nov 27, 2005 | 09:57 PM
Battle Cattle's Avatar
Battle Cattle
OK I know people have done it... I know I need to take interior panel off... but after that and using a flashlight I am completely lost as how to take it off. Then I couldnt imagine putting it back on. ANy how-tos? or special tools required?
-josh
Old Nov 28, 2005 | 05:02 AM
Yucca Patrol's Avatar
Yucca Patrol
ask koolmini
Old Nov 28, 2005 | 12:45 PM
Vinyl Styles's Avatar
Vinyl Styles
First - make sure the window is rolled up (of course) you need some allen wrenches and one has to be really long. peel back the black rubber cove on the inside door jam and there will be a little hole just big enough for the long allen wrench to fit through, you have to remove the bolt through that hole and guide it from the inside, that's the hardest one. The other one (closest to the door panel hole) can be worked on from the big opening with a flash light. The lock cable has a little **** on the end of it and it needs to be bent 90 degrees or so and popped out from the hinge. Hope this helps. good luck.
xpunisherx
Sep 1, 2015 11:47 AM
wabiker3576
R55 :: Clubman Talk (2008+)
Aug 18, 2015 08:48 PM
minimaximum
Aug 14, 2015 04:05 PM
bctf1
Aug 6, 2015 12:55 PM
