Interior/Exterior Driving light mount
Old Nov 22, 2005 | 08:43 PM
miniyellow's Avatar
miniyellow
Driving light mount
Has anyone installed the driving light mounts available from Outmotoring? They allow 2 or 4 light mount options, and they install at front bumper in front of lower grill. I was curious as to how difficult they would be to install, (if grill needs removal ect.). I really like this location.
Old Nov 23, 2005 | 09:03 AM
chows4us's Avatar
chows4us
I have. I had a shop do it but watched most of it. The wiring parts is standard stuff.
As to installation. The following were issues that needed to be resolved
  1. The dealer did NOT drill the license plate brackets dead center. So, the had to be redrilled in the bumper
  2. The holes in the bumper are NOT perfectly aligned. They ended up actually moving the bumper a bit to align (there is slop in there to move)
  3. Nothings perfect but I'm happy
  4. Make sure you use the loctite that comes with the kit. This stops the mounting brackets from working lose (which they will)
  5. Yes, you must remove the lower grille along with the whole lower bumper ... watch out for the temp sensor which they relocated because of where I chose to put the lights.
  6. Yes, you must drill holes throught the grille. Grilles are fairly cheap though ... maybe $40?
I'm happy. Good LUCK!
Old Nov 23, 2005 | 10:45 AM
Battle Cattle's Avatar
Battle Cattle
bah! a shop mod your car that wasn't an engine mod!!! PISH!!!!
-Josh
I didnt use the outmotoring mount I used the ALTA and the Mini Madness ones but they were both straight forward.... Hardest part the the wiring so that it looks good and is the way you want it.
Old Nov 23, 2005 | 12:54 PM
chows4us's Avatar
chows4us
Some of us dont have time to diddle around when other higher priority things need to be done Only watched last 10 minutes picking it up
Wohnson89
Jun 10, 2020 04:53 AM
ryGuyMCS
Oct 20, 2015 02:24 PM
JHolland
Aug 13, 2015 10:47 PM
