Interior/Exterior My OBC DIY adventure
Well I posted much early saying I have an 06 MC. I did not have the OBC feature from the factory. I went to my local dealership and asked them if they could do it, they told me no. But I went back and brought the BMW PDF document with me. I showed them that it was possible to program it. 15 min later I had the OBC. So the moral of the story, IT IS POSSIBLE TO PROGRAM THE OBC IF YOU ALREADY HAVE THE BUTTON ON THE STALK.
This is true. I can hope. I'm directly between two MINI Dealerships (Both are about an hour and a half away from where I live) so I figure I can get one of them to do it. But I already have an appointment at the one so I'm hoping they'll do it for me then.
What does BCU stand for?
I went to Lauderdale. Talk to Scott, he should know what you're talking about. you may just mention that I told you (Addison).
I left the MINI today. Scott was not there, so I spoke to Mark. I left him the PDF with the information. We'll see what happens now. He mentioned that he would have to check with the technician if it could be done and how many hours it would take...
Just got back from Lauderdale, and "I need to have equipment installed to have this feature" at a cost of $175 plus 3 hours labor...
. I guess I'll go to Braman or South MINI for my next Oil change and try with them...
Liek some one else said, if you have the A/C and the stalk with the botton. you have all the equipment you would need its just a computer thing. I guess at lauderdale they don't like doing it.
FL-Blue-Mini, did the retrofit cost you anything?
I have auto a/c, the xenons (don't know why they mention this in the PDF), and I have the button on the stalk. If I'm reading these posts correctly, it should just be a reflash with the computer, right? Let me know when you can. Thanks.
Quick question...has anyone who has not had a light stalk with the OBC button installed a light stalk and rewired for the OBC function?
I just installed a new stalk (with the OBC button), and I'm planning on wiring from behind the speedo to the stalk. I have a wire connector that I believe will fit in the slot of the connector that plugs into the back of the stalk, but there are a couple of slots, and I don't know which one to plug it into... The DIY's that I've read just state the slot on the back of the speedo connector, but nothing for the light stalk... Thanks!
