Interior/Exterior painted plastic trim
Old May 11, 2005 | 08:52 AM
MR_MINI's Avatar
MR_MINI
Anyone have any success painting the black trim around the Mini-S? The plastic has little beads on them and the local painted in my area(ATL, GA) won't do the paint job. They won't guarantee it. I like to have them painted but wonder if any has success in painting them and the process involved so that I can maybe recommend the same procedure to the loca body shop. I have one that will do it but won't guarantee it but he will listen to someone who knows how to paint them.
Any help would be greatly appreciated!
They color is dark silver/gray.
Thanks/
Old May 11, 2005 | 11:04 AM
minisme's Avatar
minisme
Yes, the black plastic trim (well arcs, bumpers, etc) can be painted. I had mine done at auto body shop that does this for many minis (the Denver Mini Dealer uses them as well).
The process is that they need to sand the plastic to a smooth finish before priming and painting. Of course all the parts that are to be painted need to be removed before this process begins.
I would not recommend being the 1st customer of a body shop to do this. I recommend finding a shop that has done this before and has some experience (and good results) doing it.
Try calling your nearest Mini dealer to see if they have done this and find out which shop they use.
Good luck!
Old May 14, 2005 | 03:45 PM
BPCooper's Avatar
BPCooper
hey
dont trust that place that you went to cause they don't know what they're doing. If they won't do it....they don't know how....just got mine done and looks sweet and wide bodied
Thanks,
Your Friend Ben
Old May 14, 2005 | 04:02 PM
BaldBikerGuy's Avatar
BaldBikerGuy
This does't sound like a real competent body shop!!
Had mine painted with no problems, should run you $6-800 with them removing/painting/reinstalling.
I'm going to have my trim painted black on my MC in the next month also, my DS MCS has the trim as well as the mirrors painted body color
Old May 14, 2005 | 04:37 PM
not-so-rednwhitecooper
hey man, where did you ho to have yours painted? i'm looking into having them done at Excalibur in Willoughby but they wanted $1800 to do it.
Old May 14, 2005 | 05:46 PM
dcsmd007's Avatar
dcsmd007
Coordinator :: PDX MINI
I removed the arches and prepped them myself with repeated sanding and priming. Then, I had the body shop to do the actual painting of the arches, the aero kit, and also some of the interior pieces. All for $450.
Hence, it will be less expansive to remove, prime, and install them yourself. :smile:
Lex2008
How to
47
Jun 15, 2022 06:18 AM
patsum
26
May 29, 2021 06:29 PM
molala
Oct 2, 2015 01:53 PM
