Interior/Exterior M7 Ultimate Grilles
Old Apr 5, 2005 | 07:52 AM
  #26
BrewSwapGuy's Avatar
BrewSwapGuy
Formerly PassatDoTd
When someone gets the production version of the black grilles please post pictures of them installed.:smile:
Old Apr 5, 2005 | 08:45 AM
  #27
Bahamabart's Avatar
Bahamabart
dam!
Those are nice grills!!! Well done.
Old Apr 5, 2005 | 10:23 AM
  #28
bee1000n's Avatar
bee1000n
Originally Posted by kaelaria
I don't like the uppers at ALL - they look like kitched grease filters
They're certainly not for everybody! As excited as I am to see a high-quality grille replacement, I'm not even sure they're for me.
I would like them better if they had some trim around the outside that could be painted body color. Basically my dream would be a metal version of the aero kit grilles.
I do think these look very purposeful and racy, though, and would help de-cute-ify my MINI.
Old Apr 5, 2005 | 10:29 AM
  #29
Herby74's Avatar
Herby74
I have had a silver lower grill on my ds/w MCS for quite a while and like the look solo......without upper and middle. The grill is also perfect for attaching a badge or two....I added an England badge on the passenger side that gives it a unique look.
Old Apr 5, 2005 | 01:33 PM
  #30
sandtoast500's Avatar
sandtoast500
Will these fit the regular MC?!?!?!?!?!?!?
Because it says "S" all over the M7 site and in all the pics.
Please say yes.
Old Apr 5, 2005 | 01:35 PM
  #31
M7's Avatar
M7
Please say yes.
Sorry but these only fit the "S" right now...
Old Apr 5, 2005 | 01:44 PM
  #32
not-so-rednwhitecooper
whats the difference b/w an s and am MC grille? ive got a grille from an MCS on my MC with no problem, along with the front bumper...
Old Apr 5, 2005 | 02:21 PM
  #33
Rally@StanceDesign's Avatar
Rally@StanceDesign
Rednwhite....have you tried putting the MCS piece onto the MC bumper? I think of any place that is where you would run into problems....
I took them and compared them, and they look exact...but maybe something is off?
Old Apr 5, 2005 | 02:26 PM
  #34
agranger's Avatar
agranger
Is anyone able to answer this?
Originally Posted by agranger
Do you get any increased wind noise with the rears (assuming they are an open design) when replacing the solid black plastic rear inserts?
Thanks!
Old Apr 5, 2005 | 09:55 PM
  #35
i dont know, but my front end is MCS now, so there shouldnt be a problem with a set of blck ones!
Old Apr 5, 2005 | 10:13 PM
  #36
TonyB's Avatar
TonyB
With my exhaust, wind noise would never be heard . If there is any such noise, I can't imagine it being too significant though...
Along those lines, I'm wondering if the flow through (yes, they are open) will help any in preventing our backsides from getting so dang dirty! It's my hope that this air movement might carry away some of the dust and debris that now gets thrown upwards, and onto our derriere...
Old Apr 5, 2005 | 10:16 PM
  #37
goin440's Avatar
goin440
The OEM upper and mid grill share the same part numbers between Cooper and Cooper S (the outter trim on top is the same, the mid bumper is exact). So the upper Ultimate grill *should* fit, whereas the mid grill WILL fit the Cooper. The lower Ultimate grill will not fit the stock Cooper bumper.
Old Apr 5, 2005 | 10:21 PM
  #38
maxmini's Avatar
maxmini
Thanks!
Ther are two ways to install the rear grills. You can do as I did and leave the aluminum heat sheilding behind the grill which will not let any air thru or yo can remove it. I have talked to one customer that removed th heat sheild and he did not notice any additional noise. My feeling is that there would be no noticable sound. If there was the easy solution would be to block off the back of the grills and they will still have a improved appearance over the plastic.
Randy
M7 Tuning
Old Apr 6, 2005 | 09:39 AM
  #39
sandtoast500
MC Upper & Middle Grill Fit
So Everyone agrees that the Upper and Middle grills will fit the MC because they are the same parts, right?
I'll probably wait for someone else to be the guinea pig on this before jumping in with both feet.
Are there any grill differences? Angle (because of the "S" scoop), or Bumper cover angles are the only potential problems I can think of.
Black on Black sure would be nice...
Also how would this work with driving lights- OEM or Piaa?
Old Apr 6, 2005 | 07:43 PM
  #40
maxmini's Avatar
maxmini
Found a little better picture of all 3 grills isntalled. As I mentioned earlier the upper grill was still in the prototype stage . The finished product fits the opening completely and has no "waveness".
Randy
M7 Tuning
Old Apr 6, 2005 | 08:09 PM
  #41
Strom's Avatar
Strom
Looks great! Did you take the same material and put it in the brake ducts? To make those did you just widen the existing fog light holes?
Old Apr 6, 2005 | 09:08 PM
  #42
Rick-Anderson's Avatar
Rick-Anderson
Randy
M7 Tuning
I cut just away sections of the heat shield in back of the rear grills. It doesn't make any noise and I like the look of my stainless Borla exhaust through the grills.
Old Apr 6, 2005 | 10:42 PM
  #43
maxmini's Avatar
maxmini
Rick that does look good , I think I will remove that insulation as well. Thanks for answeringthe noise issue directly .
Randy
M7 Tuning
Old Apr 6, 2005 | 11:02 PM
  #44
maxmini's Avatar
maxmini
I used a similar material and also cut the fog light holes wider. Basicly cut out the indented part of the lamp housing if that makes any sence.
Randy
M7 Tuning
Old Apr 6, 2005 | 11:07 PM
  #45
Strom's Avatar
Strom
Cool - did you use any tubing behind the mesh to direct air to the brakes?
Old Apr 7, 2005 | 12:40 AM
  #46
maxmini's Avatar
maxmini
Yes I used 3" metal dryer ducting.
Randy
M7 Tuning
Old Apr 7, 2005 | 08:32 AM
  #47
bee1000n's Avatar
bee1000n
Randy
M7 Tuning
Are those black?
Old Apr 7, 2005 | 09:04 AM
  #48
no_affiliation's Avatar
no_affiliation
makes the car look cheap... i could see these same cars with neons behind that mesh
Old Apr 7, 2005 | 05:41 PM
  #49
maxmini's Avatar
maxmini
Originally Posted by bee1000n
Are those black?
The bottom one is production black powder coat adnthe top two were just spray painted and are actually more glossy than the actual production pieces.
Randy
M7 Tuning
Old Apr 8, 2005 | 03:19 PM
  #50
conehead's Avatar
conehead
So let me see if i have this straight. Your car is the one pictured with " sugar " painted on the dash with all the little stars and you say that the grills make that car look cheap? If anything deserved a nice blue neon glow it has to be " SUGAR "
