Interior/Exterior Aftermarket seat with airbag light?
Old Feb 10, 2005 | 07:12 PM
S1monLM's Avatar
S1monLM
I putting my Pole Position in my MCS this weekend, does any know how to shut off the light after install or can I bring it back to the dealership and have them reset it? Any tips?
Old Feb 10, 2005 | 08:51 PM
TheOfficeMaven's Avatar
TheOfficeMaven
Check this Randy Webb how-to out as it explains how to do just what you're after:
http://www.webbmotorsports.com/forums/viewtopic.php?t=9
Look at step number 7.
Old Feb 11, 2005 | 02:43 AM
S1monLM's Avatar
S1monLM
Is there anyway I can get the factory airbag sensor and plug it back in instead of using 4 ohm resistor to trick the sensor?
Old Mar 8, 2005 | 01:01 PM
jblow's Avatar
jblow
I'm very interested in any insight on this issue as well - bump
Old Mar 17, 2005 | 07:58 AM
770 KOF's Avatar
770 KOF
Here's the correct resistor with no soldering involved.
I found a 3.3 OHM 2 watt resistor at my local electronics store that has wire that's a perfect fit for the airbag connector. it's made by NTE Electronics (www.NTEINC.COM) and the part number is 2W3D3.
Hope this helps anyone installing an aftermarket seat. I had no problems whatsovever. The wires on the resistor are a perfect (i.e. snug) fit into the wiring harness connector. Just bend the wires on each end of the resistor at ninety degrees so they line up with the holes in the socket and push them in as far as they will go. Wrap the whole connector and exposed wires with electrical tape.
As far as I know there's no way to stop the SRS light from comming on other than with a resistor. I guess you could remove the airbag from your seat and plug it in but that would be potentially dangerous and would ruin your OEM seat.
Trust me go the resistor route.
Teh
Jun 13, 2018 02:59 PM
one73ronin
Aug 19, 2015 12:36 PM
DWooderson
Aug 10, 2015 09:12 AM
quality_sound
Aug 7, 2015 09:36 AM
