Interior/Exterior OEM Steering Wheel Spacer?
Old Oct 24, 2017 | 08:27 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Does anyone know of a steering wheel spacer that will work with the OEM JCW steering wheel? I would really only like the wheel about 1" closer. The sotck telescoping only gets the wheel so close, and in my seating position, its just not close enough.
Perhaps, something like this:
https://forum.miata.net/vb/showthread.php?t=654504
Old Nov 1, 2017 | 07:53 AM
bugeye1031's Avatar
bugeye1031
Moderator
Good idea
I'd like the same exact thing....the steering wheel in my '09 needs to come about an inch closer to me to feel right. I could still reach the stalks, but I could place my seat for a better fit for my legs.
Old Nov 1, 2017 | 11:24 AM
bugeye1031's Avatar
bugeye1031
Moderator
Blue Sky Ideas
Might be a little extreme, but I wonder if one could cut off the hub from a steering column, cut out the core from a steering wheel, and weld them together to fabricate an adapter.
https://www.allmagautoparts.com/coll...41-32302755517
https://www.allmagautoparts.com/coll...15-32306794624
another option might be to 3D print something
https://www.xometry.com/cnc-machining-service
Old Nov 1, 2017 | 11:51 AM
cstrumol's Avatar
cstrumol
I'm thinking that lopping off the splined hub of the steering wheel and tacking it together with another would be best bet. As long as nobody super short drives the car you will probably be fine. Would love to give this a try but I might be moving soon and cant take on a new modification project now haha. Depending on how far the splined portion of the rack goes through the wheel, you might be able to get away with just throwing some spacers in there also. There aren't huge forces put on the steering wheel, as long as you have at least 3/4 of the splines touching id say you're good (im no engineer haha).
Old Nov 1, 2017 | 12:34 PM
bugeye1031's Avatar
bugeye1031
Moderator
I thought about that, too....esp the washers, but didn't want to risk it...when I had steering wheel off, it didn't seem like the hub was long enough...
Good luck with the move....they always take so much energy!
