Interior/Exterior 2009 R56 Side Reflector
Old Nov 15, 2013 | 06:09 AM
mkoutnik's Avatar
mkoutnik
Does anyone know where I can get a replacement side reflector for the front passenger side and a replacement bulb socket for the reflector. The reflector was broken when I bought the car. Now, the light bulb assembly has water in it and the bulb socket no longer works due to corrosion of the contacts.
Thanks in advance.
Old Nov 15, 2013 | 06:53 AM
Here is the front side markers. All these come with the socket for the bulb & bulb.
Side Light Marker - Front Left 63132751331
http://www.ecstuning.com/Search/SiteSearch/63132751331/
Side Light Marker - Front Right
http://www.ecstuning.com/Search/SiteSearch/63132751332/
Here is the rear side markers.
There is the rear left (driver) and right (passenger) hand side.
Side Light Marker - Rear Left
http://www.ecstuning.com/Search/SiteSearch/63132751333/
Side Light Marker - Rear Right
http://www.ecstuning.com/Search/SiteSearch/63132751334/
They are not hard to replace , you can see the tab inserts into the top and should be a little nut on the back of the old one that is on the peg.
Thanks and good luck.
Old Nov 15, 2013 | 08:42 AM
mkoutnik's Avatar
mkoutnik
Awesome Web Site! Thank you.
Old Nov 25, 2013 | 05:55 AM
Thanks,
Glad I could help.
Old Feb 3, 2016 | 04:42 PM
Blur's Avatar
Blur
Anyone know where I can get a smoked set and not the film application?
Old Apr 14, 2016 | 11:35 PM
Blur's Avatar
Blur
https://www.northamericanmotoring.co...right-way.html
Old Apr 18, 2016 | 06:37 PM
kipper3d's Avatar
kipper3d
Sorry to hijack this but I'm new and not sure best place to post. I cracked my passenger side marker on a low object I didn't see in parking lot. I've bought the replacement, unfortunately I cannot get the old one off!! Its like its glued on or something. I have take out the head lamp to get to the bulb which I've pulled out, but to push the reflector our is impossible without damaging the plastic holding it in place.
Anyone know of any special way to get the old one removed? The inserts on the inside almost appear fused with the holes.
Thanks!
-Kip
Sexual Chocolate
Mar 31, 2019 08:02 PM
marendt428
Nov 14, 2015 10:03 AM
cm.d
Aug 19, 2015 08:51 AM
marendt428
Aug 8, 2015 04:44 AM
