Interior/Exterior 2012 tail lights vs 2013
Old Jun 5, 2013 | 07:33 AM
JONNYBOY's Avatar
JONNYBOY
Hey guys I just got a 2013 cooper s and ive been looking everywhere for tail lights, I found a bunch for 2012 models but only one for 2013. My question is, does anyone know if there is a difference between the two years or would the 2012s fit in my 2013? thanks in advance
Old Jun 5, 2013 | 07:43 AM
RoyalCooper's Avatar
RoyalCooper
Best I've been able to tell anything post 2011 is the same; so if it works for a 2012 it will also work for a 2013.
Best place to check compatible part numbers is here:
http://www.realoem.com/bmw/select.do
I know at first it looks like a BMW site but scroll thru the series column until you find your Mini
Then you can look up your vehicle and a 2012 version...if the part numbers match you can be pretty sure you'll be OK.
This might shed some light (pun intended) too:
https://www.northamericanmotoring.co...ht-set-up.html
Old Jun 5, 2013 | 07:47 AM
JONNYBOY's Avatar
JONNYBOY
wow, thatll be a big help! thanks a lot im gunna look through it now
Sexual Chocolate
Mar 31, 2019 08:02 PM
dyeLucky
Sep 11, 2015 10:41 AM
cm.d
Aug 19, 2015 08:51 AM
messyjesse96
Aug 12, 2015 05:51 AM
