Interior/Exterior Has anyone installed the steering wheel from R56 to R53?
Old Dec 30, 2012 | 07:34 AM
Carbonbaby's Avatar
Carbonbaby
I want to install a steering wheel from R56 to my R53. Now there is a two spokes steering whee with multifunction. I have an anatomy sporty R56 steering wheel with multifunction and brand new AIRBAG also from R56 three spokes steering wheel. Can they dock? Somebody already did that?
Old Dec 30, 2012 | 09:11 AM
minsanity's Avatar
minsanity
Many did 1st gen 2-3 spoke swap. Have yet to see what you plan. Good luck,
Old Dec 30, 2012 | 09:33 AM
Carbonbaby's Avatar
Carbonbaby
They do swap 1st gen 2-3 steering wheel, but they use 3 spokes wheel from restyling 1st 3 spoke steering wheel. I want swap 1st gen 2 spokes steering wheel to 3 spokes R56 steering wheel.
Old Dec 30, 2012 | 09:46 AM
minsanity's Avatar
minsanity
I understood that. As I've said, I've yet to see 1 who has tried. You can check by removing your 2spoke & check if airbag, MFSW, spline & indicator auto-cancel all fit.
Remember to disconnect your battery/unplug SRS fuse. It'll throw the SRS light once fuse is out, but won't store any codes to clear. Should R56 airbag have same resistance as your 2 spoke, light should turn off when fuse is back in. Hope you sort it out.
Old Dec 30, 2012 | 09:58 AM
Carbonbaby's Avatar
Carbonbaby
I've a friend, he is an electrician in BMW dealership station. He said that the R53 and R56 SRS Airbag resistance is the same. Hope they are mechanically compatible.
Old Dec 30, 2012 | 10:41 AM
rkw's Avatar
rkw
1st and 2nd gen steering wheels are mechanically incompatible. People have tried to swap JCW steering wheels between generations and not been successful.
Old Dec 30, 2012 | 10:42 AM
minsanity's Avatar
minsanity
Then the SRS is 1 item less to worry about. Removing the 2-spoke is easy. To Torx screws hold the Steering airbag. Horn is the 4pin plug w/ 2wires- brown & white. The MFS plug is to the left of it. Open & check if you're really bent.
Like what rkw said, that must be the reason why we haven't come across any 1st-2nd gen wheel swaps.
Zettinger
Aug 25, 2015 04:04 PM
skippermini
Aug 12, 2015 10:05 PM
nomar116
Aug 12, 2015 05:24 PM
MES11
Navigation and Audio
Aug 6, 2015 08:52 AM
