Interior/Exterior OEM alarm still available for the R53?
Old Apr 3, 2012 | 04:14 PM
chuckee98's Avatar
chuckee98
Just picked up a 2005 R53 which previous owners did not equip with an alarm. Is the OEM alarm still available, or am I out of luck since production of the R53 ended 5 years ago?
Old Apr 3, 2012 | 08:16 PM
ZippyNH's Avatar
ZippyNH
Just call your dealer and see if there is one sitting on a shelf somewhere...and be sure to ask the $$ and the +$$ for the retrofit. I bet 100 to 1 that you can get an aftermarket alarm for less $, with more features....
Old Apr 3, 2012 | 10:55 PM
Eric_Rowland's Avatar
Eric_Rowland
Someone, somewhere, has an OEM alarm. As Zippy said, you can probably get aftermarket for less. For me, I appreciate the integration of OEM. The key is to get the current holder to believe that you're the last person who is ever going to want a R50/53 OEM alarm. FWIW, I got mine for $150 (+$70 BCM reprogram)
Old Apr 3, 2012 | 11:52 PM
rkw's Avatar
rkw
It's still listed in accessory sales, and dealers can probably still order the parts from MINIUSA. Here are the prices at Morristown MINI: http://www.shopminiusa.com/PRODUCT/5...CenterId=30253
In addition to the alarm module itself, you also need to purchase a turn signal or wiper stalk with the blinking light, and have a dealer program the alarm into the computer. Here are installation instructions if you want to do most of the work: http://motoringfile.com/files/alarm_retrofit.pdf
Old Apr 4, 2012 | 03:42 AM
chuckee98's Avatar
chuckee98
My intention is to do the install myself, and have the dealer do just the programming. I understand that aftermarket is the cheaper option, but I prefer plug and play, and not having to add an addition remote, since the OEM is integrated with the ignition key. If I chose aftermarket, I would probably end up doing the install myself anyway.
Thanks for all the info, especially the links. Having the associated part numbers help immensely in my search.
blackie
Oct 2, 2015 07:41 PM
maniacalmorgan
38
Sep 29, 2015 04:56 AM
Aug 19, 2015 12:51 PM
FLYM1N1
Aug 16, 2015 01:15 PM
