Interior/Exterior Is the R56 LCI clear tail light lens removable?
Old Mar 8, 2012 | 11:10 AM
oldsbear's Avatar
oldsbear
When I Plasti-Dipped my tail light rings I didn't notice if the clear lens is removable. It is not listed on Real OEM as a separate piece, so I suspect it is a permanent part of the tail light assembly.
Does anyone know for sure?
https://www.northamericanmotoring.co...light-0356.jpg
Old Mar 19, 2012 | 11:15 PM
rayzmini's Avatar
rayzmini
I tried getting mine apart (ala the joey modd) however i could not... took it apart as much as i could but the clear piece is stuck or permenatly sealed or glued to the red lens :(
Old Mar 20, 2012 | 07:11 AM
oldsbear's Avatar
oldsbear
Originally Posted by rayzmini
...the clear piece is stuck or permenatly sealed or glued to the red lens :(
Well, that is crappy Thanks for the information.
I saw on RealOEM that a MINI blackout set appears to be available. I sent emails to three vendors, but haven't heard back from them. A Google search for the part number(s) turned up nothing.
Old Mar 20, 2012 | 07:27 AM
Spridget's Avatar
Spridget
Most likely to keep moisture - and condensation - out.
Spridget
Old Mar 20, 2012 | 12:34 PM
AdrenaliNate's Avatar
AdrenaliNate
I tried the same thing since I wanted to black-out the chrome cup. I agree, it looks some some sort of hardened glue that would break before it softened up.
Old Mar 20, 2012 | 04:02 PM
countryboyshane's Avatar
countryboyshane
You need a whole new taillight if you don't want the egg yolk look.
Sexual Chocolate
Mar 31, 2019 08:02 PM
dyeLucky
Sep 11, 2015 10:41 AM
cm.d
Aug 19, 2015 08:51 AM
messyjesse96
Aug 12, 2015 05:51 AM
