Interior/Exterior rear Speaker Grill
Old Feb 19, 2004 | 03:29 PM
NWMINI's Avatar
NWMINI
What is the easiest way to remove the rear speaker grill? I have a small dent I would like to remove? How hard is it to remove rear panel? Yuk!!!! Help!!!
Old Feb 19, 2004 | 06:04 PM
Storer's Avatar
Storer
There isn't an easy way... do a search for a rear speaker install for isntructions. You essentially have to strip the rear of the car. Not technically difficult, but time consuming. Just make sure you give yourself plenty of workspace to put all the parts.
Old Feb 19, 2004 | 06:18 PM
dcsmd007's Avatar
dcsmd007
Coordinator :: PDX MINI
No easy way out of this one! Do be careful when refitting the panels, which I found tricky. If not properly installed, you'll end up getting the unwanted rattles.
Old Feb 20, 2004 | 06:27 AM
Storer's Avatar
Storer
I found that when my car was repaired after a major accident (18 hours after I picked her up, lovely, no?), that the body shop did not replace all of the "poppers" that attached the interior panels to the body. To this day I still have some unwanted noise. This spring I plan on buying a bag of poppers and going back to work. Going to install Dynamat while I'm at it. I hate rattles...
wkp1219
Nov 13, 2015 07:52 AM
Mini'mon
Aug 26, 2015 01:02 PM
OutMotoring
Aug 6, 2015 09:32 AM
