Interior/Exterior removing rear seat
Old May 7, 2011 | 12:18 AM
BRR9's Avatar
BRR9
removing rear seat
i am having a hard time finding tips on getting the rear seat out if you hav any please help
thank you
Old May 7, 2011 | 04:28 AM
2Miniacs's Avatar
2Miniacs
Top or bottom portion of seats? For the tops you have to remove the bolt at the back of the seats (10MM Socket) and then there's a retainer at the top of that bracket you slide forward. Once you've done that, pull the inside portion of the seat up, tilt the seat forward to about 45 degrees and pull to the inside. You can normally rotate the seat back and forth until you find the slot that lets the outside slide out.
Old May 7, 2011 | 06:49 AM
buzzsaw's Avatar
buzzsaw
Here's a DIY write-up that might help. Good luck.
flyers47
Jul 27, 2020 02:38 PM
mishanja
Jun 22, 2016 09:59 AM
Mini'mon
Aug 26, 2015 01:02 PM
mini4thewini
Aug 19, 2015 05:18 PM
