Interior/Exterior Help with retrofitting new Mirror with UGO
Old Nov 13, 2010 | 08:36 AM
mikemeadows71's Avatar
mikemeadows71
I just purchased a new 2011 Cooper S that does NOT have the auto dimming/garage door opener mirror. I ordered one and it came in and i installed it and it does not work. I called the dealer and they said that since 2007 you are unable to retrofit a mirror with the garage door opener. Does anyone know if there is a fix for this problem..Cheers..m
Old Nov 13, 2010 | 09:05 AM
Chris G's Avatar
Chris G
You should be able to retrofit it - if I am remembering correctly, I've seen it done a few times. I know there is a special harness for the UGO mirror. I also thought there was some dealer programming involved. Wish I could provide more information, but it's been awhile since I worked at the dealership.
Old Nov 13, 2010 | 05:32 PM
rkw's Avatar
rkw
What did you connect it to? The UGO mirror is a self-contained unit and only needs 12V power to operate (no programming). A car without UGO mirror from the factory might not come with the connector harness, but there are 12V power sources in that roof console area you can connect to. The only unusual thing is that there is also a connection to the backup light, which is used to prevent the mirror from dimming while backing up.
Old Nov 25, 2010 | 11:28 PM
robspec's Avatar
robspec
a harness needs to be added ill se if i can dig up the bulletin
Old Nov 26, 2010 | 11:49 AM
RllyDrvrIX's Avatar
RllyDrvrIX
Dealer told me it would not work. The necessary wiring would not have been installed at the factory.
I would lov to know it can be done and how...
Old Nov 26, 2010 | 02:34 PM
rkw's Avatar
rkw
The only necessary connections are 12V power and ground. If you are handy with wiring, it shouldn't be difficult to connect them. You can tap into a 12V source up in that roof console area.
As I said earlier, the mirror also uses a connection to the backup light, but the connection isn't necessary for regular operation.
gar56
Nov 15, 2016 06:41 AM
vulkandino
Oct 31, 2015 08:29 PM
penguinplf
Oct 11, 2015 07:36 PM
ahorvath
Oct 3, 2015 01:13 AM
MCSNY
Sep 29, 2015 10:17 AM
