Interior/Exterior VEI V1 Remote Display
Short video of it.
Install instructions. Looks like it has a wire for illumination and for a remote mute switch. It has a button on the face for mute too. They offer it in red, blue, and orange display colors.
Instructions-VRD-M.pdf
I have the V1 mounted above the mirror so a mirror display wouldn't be of any use since it's only an inch or so away from the V1 display.
I'm probably going to get one of these in black and pair it with a Aeroforce Interceptor gauge to replace my Scangauge II. Does nearly everything the Scangauge does (plus boost) but in a round dual display all through the OBDII port.
Attachment 49569
These should look good together.
Attachment 49569
Been eye-ing that for a while now. Finally took the plunge and ordered a V1. The VEI remote display seems to be one of the simplest/cleanest remote displays. My only thought is if the Orange color matches the factory amber well.
OK. Looks like it comes in red, orange and blue.
http://www.vgauges.com/catalog/produ...10e981eaa06878
It's pretty easy to clip it on the headliner by the mirror using the visor clip that comes with the V1 and fish the power wire down the fuse block. An add-a-fuse powers mine.
They have an orange model. Color looks like this (not actual V1 gauge).
I'll be ordering one of these with the orange LEDs and black housing soon. I will post a shot of it when I get it in the car.
I picked orange after seeing how the red looked compared to the tach display in this video.
According to VEI, the orange was designed to match the newer BMWs (335i, etc). So I suspect it will be fairly close to the Mini's orange.
Good to hear the lighting matches, I ordered one last night. Will post pics once it's installed.
Let me know which wire you use for the illumination connection if you plan to use that feature.
Hopefully all the parts come in by Wednesday/Thursday so I can have everything installed by the weekend. I'll be sure to post pics of it all.
Well, I have the parts. I had to pull out some sand paper to take down a couple of high spots and it fit right into the gauge cup from Craven Speed. The studs on the back are too short so I'm going to have to figure out something for that but otherwise, it went that far with no problem. Just did the install and it was just about as easy as anything I've ever done. I didn't wire up any lights yet and after seeing it, I don't know if I will...
Here are a couple of pictures with and without a flash. The brightness is set at 1 (of 9) otherwise, I think I could drive by the brightness of the light.
That looks good. I filed down one of those set screws in the gauge itself to make it fit the Cravenspeed pod. The thread size on the studs are 6/32. You can unscrew them and use long screws or longer studs. Just don't over tighten them. They have a stop inside the gauge but it's not very robust.
You must have gotten the silver/chrome trim ring. My gauge is all black. I'm getting the Aeroforce Interceptor gauge to replace my Scanguage, which is also all black. The two match well together. I'll post pictures once I'm done installing them (probably next week).
Great info! I'll take a look at those studs and make the change so I can secure the gauge in the cup. I had to sand down both of the guages set screws to get it in the cup but that took all of about 45 seconds. I actually ordered the black guage as well but chrome arrived in the mail. No biggie, I can fix that. I'm impressed with the device itself and it's really cleaned up the install.
I swapped a PM with Kellen at CS and he said they dropped the set screws in the guage cup to keep them looking "cleaner" and I can understand that. The metal backplate and studs going through it should be more than enough to keep the guage from turning in the cup. Of course, the studs are spaced differently than the pre-drilled holes in theh backing plate but again, that's a 2 minute fix.
Looking forward to your pics!
my car went in for some more additions today and my V1 is one so this is a nice post for me. but i was hoping that someone who has done the leg work could post a few links like for the Aeroforce Interceptor gauge (didnt find for the mini or in black but for the one i did fing set for other vehicles, does it clear codes?), the V1 gauge (also couldn't find in black casing) and the craven speed pod holders to fit one on each side, in one post that are mentioned in this thread.. if that's possible that would be a big
this has my wheels turning already that's for sure..
