Interior/Exterior Help Needed.
Old Aug 12, 2010 | 09:15 PM
TBangin23's Avatar
TBangin23
Help Needed.
Alright so a few days ago I purchased a new pedal set for my 2003 MINI. It included four pedals. Dead petal, clutch, brake, and gas. With the "kit" it included a few screws and bits and pieces, and then double sided tape. I got the kit from Moss MINI. Can anyone help with the install? I'm completely stumped. I've already tired to get ahold of Moss MINI and no response yet. Any help would be helpful. Thanks guys.
Old Aug 12, 2010 | 10:35 PM
MiniKar's Avatar
MiniKar
From the photo you have posted, you should have 8 screws ???
Are the screws self taping ??
Moss has been good to me about returning emails when asking install instructions. I would give them a call tomorrow AM and tell them no instructions we're included with the Pedal set.
I know when I installed a set like this in my ( Porsche ) the screws went right into the stock gas pedal and dead pedal. As far as the clutch and brake I removed the stock rubber and screwed into the metal backing.
Before doing this, just give them a quick call . . . . . . . . . . .
Old Aug 12, 2010 | 10:41 PM
TBangin23's Avatar
TBangin23
Alright, i will give them a call tomorrow morning. Do you think they'd send me instructions? Or just tell me what to do. I'm pulling for intructions... Easier for me. And yes, there are about eight self tapping screws..
Old Aug 13, 2010 | 07:52 AM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
The Ultrik set requires drilling holes and there is a template for that. Could be your set up is a bit less "complicated" hence the double sided tape.
As it's not an OEM replacement part I find it odd no directions came with them. But as with most manufacturers these days from weed trimmers to auto parts, instructions usually can be located at each manufacturers own web sites. ( must be cheaper than printing all that paper most folks dont bother reading anyways )
Old Aug 13, 2010 | 08:30 AM
TBangin23's Avatar
TBangin23
I checked their website, no directions there.
Old Aug 13, 2010 | 09:21 AM
JumpingJackFlash's Avatar
JumpingJackFlash
I bought a pedal kit for my old '02 MCS. You screw in the dead pedal and accelerator pedal covers directly using self-tap screws. You may also have to bend them slightly so they contour with the factory curve of them.
The clutch and brake pedal covers have to be drilled, and there should be machine screws with locking nuts for them. If memory serves, I held them in place as best I could and used a scribing tool to mark where the holes were at. It was a bit of a pain to drill them (unless you have a lift to bring up you MINI a bit off the ground). The clutch pedal is easier, as it is made of a polymer. The brake pedal is steel.
Old Aug 14, 2010 | 08:29 PM
TBangin23's Avatar
TBangin23
thank you! just got done installing my set. looks great.
Filmy
15
Jun 6, 2023 06:27 AM
BenjiFace
Dec 20, 2015 06:56 AM
NorthWestEuro
Oct 21, 2015 08:11 PM
Flyboycoy
14
Sep 24, 2015 06:32 AM
honderpilot
Sep 21, 2015 09:13 AM
