Interior/Exterior locking glovebox retrofit
#26
Well, the chrome button mechanism appears to be exactly the same as the non-lockable kind except for the hole in the middle for the lock cylinder. Basically, this means that if MINI is willing to code a cylinder to match the key on an R56, it should work.
#27
UPDATE: I just found out that if you try to order a lock cylinder by submitting your hardtop vin# it would be rejected. So, that would mean this an impossible mod UNLESS you happen to find a newly salvaged Cabrio, Coupe or Roadster and can strip out the door lock cylinder, key and glovebox lock mechanism, while taking note of the VIN for future reference, then swapping in both lock cylinders.
This is assuming there's no chip in the key which would cause immobilizer issues when trying to start the car.
It's a real shame this mod is practically impossible to do, given how practical it would be to have a locking glovebox.
#28
Just went to the MINIUSA site and sent them a note requesting clarification as to why we shouldn't be allowed to "you-ify" our MINIs with a glove-box lock. I obviously have a hard time letting this go!
see text below:
Hello.
I have a 2013 Cooper Hardtop. I recently noticed that several of the other models (coupe, roadster, convertible) come equipped with a lockable glove-box. I would also like to have the added security of a lockable glove-box. I did some research and found I simply need to purchase 2 parts in order to retrofit this feature:
51167262826 lock cylinder AND
51162756623 lock mechanism with hole for cylinder.
Unfortunately, I've been told by the dealer that I cannot order the lock cylinder because my VIN is for a car which did not come with one. This is puzzling since there's no legal or safety reason I can think of why I should not be allowed to have a lockable glove-box on my vehicle even though it wasn't offered from the factory. How may I go about getting permission to purchase a lock cylinder coded to my car? The VIN is shown above. I eagerly await your reply.
Thanks!
Joe
see text below:
Hello.
Thanks!
Joe
#29
#30
#31
#33
Well, it's been almost 5 months and it took a few emails and phone calls back & forth to MINI USA but I was eventually given permission to order a lock cylinder.
The cylinder and lock button arrived today.
I can't wait to install them! It looks like there are a couple of hidden screws along the top of the kneebar piece I'll have to find and remove first.
Thank you Bill @ MINI USA and Sean at http://thebmwminipartstore.com/
#34
Success! Time for a beer!
UPDATE:
Lock is installed and works correctly. It was a learning experience, removing the A-pillar trim and dashboard end piece (surrounding the vent) in order to expose the one screw on the far right. It was also a challenge clearing the far left screw from its' hole because the plastic lip on one of the center vents keeps it from coming all the way straight out. I didn't mind, I want to become more familiar with how this trim comes for future mod projects.
#35
UPDATE:
#36
Yes, the MINI USA rep got authorization for me from corporate and so when I ordered my parts online from the MiniPartStore, I included a message with my order to contact the rep, Bill S @ MINI USA.
Sean, the guy at MiniPartStore was then able to order the lock cylinder coded to my key.
If you're interested, the dealer I got the parts from is:
Sean is the internet parts sales guru.
#37
Thanks for your effort.
#38
Bill S (at MINI USA. 866.275.6464, extension 7305) was the third rep I was in contact with, the first 2 didn't even understand what I was trying to do, kept reading me stupid scripted responses about how sorry they were that I was unhappy with my glove-box. It was infuriating.
The reason I recommend going right to him instead of any other rep at MINI USA is because he has experience with this and would know what to do.
If you contact Sean L at the BmwMiniPartStore, he may also already know exactly what to do since it's now been done before. He might just need to submit your VIN to get it authorized for a key cylinder order. By default, only VINs for convertibles and roadsters get authorization for this part.
If not you'll have to contact Bill S first to get authorization before placing your order. I wouldnt be surprised if each person that does this needs to contact the manufacturer first. It is a German company, after all, with a set bureaucracy.
***Make sure to refer to your VIN when you contact them and when placing your order. They'll need it to figure out what your key code is.***
#40
#41
Well, to be fair, it's not a high security lock but if it's too much of a hassle, a potential thief would probably just give up, especially if they're in a hurry.
I didnt take any pics, it's a pretty straightforward job.
remove a pillar cover
remove dash end cap
remove kneebar section containing latch now that you've exposed all the screws hidden by other trim
assemble lock cylinder into new latch
pop out old latch
pop in new latch
reverse steps to reassemble.
have a beer.
remove dash end cap
pop out old latch
pop in new latch
have a beer.
#42
Still useful
So this thread is pretty old but I just wanted to say I still found it useful! I went back and forth with Mini and the BMW Mini Parts Store but neither was able to help. The parts store eventually said they might be able to send the lock cylinder without coding it, but by then I had already bought a used one from eBay. So if you can get a used one or an uncoded one, it’s not difficult to code to your key. YouTube!
bugeye1031 (05-04-2018)
