Interior/Exterior relocating factory driving lights
Old Mar 5, 2010 | 08:28 PM
littlecS's Avatar
littlecS
Hello all!
Just about to remove my factory driving lights to plastidip them and thought, since I was going to go through the trouble of removing them, why not mount them in the lower grill?
Just curious if anyone else has done this with the factory lights. I've seen it done plenty with the light bar, but I don't think thats my style.
Post pics if you got 'em, and I'll post mine when im done!
Old Mar 6, 2010 | 07:57 AM
meh's Avatar
meh
Here's mine
Old Mar 6, 2010 | 12:14 PM
littlecS's Avatar
littlecS
That's clean, did you make little brackets for each of the lights?
Old Mar 6, 2010 | 07:02 PM
meh's Avatar
meh
No brackets-just a single aluminum plate cut to fit underneath the fascia with 4 holes drilled in it. It ties all the lights together; they do rock a little but work well.
Old Mar 7, 2010 | 04:03 PM
littlecS's Avatar
littlecS
oh ok, so you drilled holes in the lower black plastic on the bumper, i see it now. I couldn't tell if you had the wires running from underneath or from behind the grills. thanks!
Old Mar 8, 2010 | 02:25 AM
danmay's Avatar
danmay
Originally Posted by meh
that looks amazing!
Old Mar 8, 2010 | 02:43 PM
meh's Avatar
meh
Originally Posted by danmay
that looks amazing!
Thank you...
Old Mar 8, 2010 | 04:07 PM
N2MINI's Avatar
N2MINI
or here is another idea.. Less to wash around!!!
Old Mar 8, 2010 | 07:10 PM
littlecS's Avatar
littlecS
woww, thats an original idea, I kinda like it! Did you do that yourself?
Old Mar 9, 2010 | 07:16 AM
N2MINI's Avatar
N2MINI
Yes, they are mounted to the bottom of the alum bumper brace.
Not actually factory MINI lights, though they may work as well..
At the time I hadn't seen it done and thought I'd be different..
Old Mar 9, 2010 | 07:04 PM
littlecS's Avatar
littlecS
Well that is just sweet! I hope you don't mind if I "borrow" some of your ideas because you've inspired me!
I won't if you disapprove....
Old Mar 10, 2010 | 03:09 AM
N2MINI's Avatar
N2MINI
No problem, go right ahead!!!
Old Mar 11, 2010 | 12:33 PM
jbkone's Avatar
jbkone
THAT is a really clean install N2MINI!! I'm impressed with how "stealth" it looks.
Old Mar 13, 2010 | 03:53 AM
N2MINI's Avatar
N2MINI
Thanks jbkone,
It was pretty easy. Just have to have thin lights as you only have about
2-1/2'' or so of space down there to play with..
Old Nov 4, 2010 | 07:32 PM
LetsMotorR53's Avatar
LetsMotorR53
Hard to install?
Old Nov 5, 2010 | 09:12 AM
N2MINI's Avatar
N2MINI
Pretty easy. I've actually done it twice and for some reason I did it quicker the first time. They had different brackets though.. Before taking bumper cover off get a couple of measurements for height and how far right and left of center you want them to appear in the lower grille area.. Mount brackets to bottom of alum bumper brace attach light and test fit bumper cover..Adjust as needed..
Old Nov 5, 2010 | 07:44 PM
LetsMotorR53
nice. Well they look sweet, and different!
Wohnson89
Jun 10, 2020 04:53 AM
Dec 23, 2015 10:36 AM
ryGuyMCS
Oct 20, 2015 02:24 PM
JHolland
Aug 13, 2015 10:47 PM
