Interior/Exterior Best Cooper S Driving Lights...
Old Jan 25, 2010 | 03:48 PM
  #26
martinb's Avatar
martinb
I really don't like the idea of huge lights on the front of my Mini, though I know it's a very cool and retro look. It's just not for me. And I've been thinking that HID driving lights would be way superior than conventional halogens. So, I've found these two possibilities. They're designed more for motorcycles and are therefore quite small, but they're HID and put out about 3 times the light as a 55 watt halogen. Has anyone tried them? Or seen anyone who mounted them?
http://www.shopatron.com/products/pr...PIA73082/353.0
http://www.martinfabrication.com/Mar..._LIghts.html#2
There small enough that it might even be possible to recess them completely or partially into the grill. (I'm running the JCW aero kit on my 06 cab.)
Old Jan 27, 2010 | 03:18 PM
  #27
martinb's Avatar
martinb
'Just did some more research on the PIAA's and the Martin Fabrication lights.
The PIAA's are only 25 watts, use an MR-16 type HID lamp (like in projectors and track lighting), and are actually made by TrailTech.
The Martin Fabrication lights are true 35 watt HID (like most HID driving lights), the reflectors and ballasts are made by some high end European manufacturer (no cheap stuff from China), and are DOT, TUV, approved as well as approved in Japan, I believe.
Seems like the Martin Fabrication is the better bet. And I talked with the owner and he says that no one has ever returned a set, even though he says he'll take them back no questions asked if you don't like the light output.
Nice.
Oh, and the Martin Fab lights are are a hair over 2.5" in diameter and a hair over 3" in length. That's nice and compact. And for the standard kit, they're only 399.95 a set. That beats a lot of the other HID lights out there for sure.
Old Feb 2, 2010 | 08:10 AM
  #28
TSR53's Avatar
TSR53
Another mounting option.
"HL29000 Bracket Kit to mount two lamps on New Mini. Includes brackets, hardware. Will mount all Current Hella Lamps Except Rallye 4000, 3000 and 4000 Compact. Lamps not included."
http://www.rallylights.com/detail.aspx?ID=3946
"HL29001 Cross bar for Mounting Additional Lamps on New Mini, Includes two (2) HD Hood Gas Springs. For use with HL29000 Mini Brackets. Lamps not included."
http://www.rallylights.com/detail.aspx?ID=3947
Old Feb 2, 2010 | 03:09 PM
  #29
anmracing's Avatar
anmracing
Wow! That's where I got the lights from and didn't even see the brackets. I'll have to look into those now......
A~
Old Feb 2, 2010 | 03:14 PM
  #30
anmracing's Avatar
anmracing
Dang it!!! The brackets wont fit with the lamps I bought... That would figure. Looks like I'm gonna be fabricating some brackets....
A~
Old Mar 3, 2010 | 09:10 AM
  #31
anmracing's Avatar
anmracing
Finally got them on..... I just extended the bracket with a piece of metal to get them to accomodate the Angel Eye lights. They are pretty big.... The front end is too heavy and is raked down now..... JK....
My company recently did a Ride and Drive with Yokohama. Seems the local Mini club got to participate the day before. They had these sweet traffic cones that I could not resist getting a photo op with....
Here's the link to the pix I took that day.
A~
Old Mar 3, 2010 | 09:14 AM
  #32
anmracing's Avatar
anmracing
BTW for those of you that want a smaller light, I found these in my research. They look pretty cool!
A~
Old Mar 3, 2010 | 09:47 AM
  #33
TSR53's Avatar
TSR53
Nice, Hella Rallye 4000 compacts - looks great! Please post up some more photos of a side profile, detail mounting and looking from the top down, TIA!
Old Mar 5, 2010 | 01:15 AM
  #34
mcsNathan's Avatar
mcsNathan
I bought the Mini driving light kit and fitted them myself which was not fun and took forever. I was a little disappointed when I found out they only come on with the high beams, I may go back and rewire them to come on with the fog lights. They do look fantastic though. Thinking about switching out the bulbs too for something a little less yellow and brighter.
Old Mar 27, 2010 | 10:00 PM
  #35
robinj's Avatar
robinj
my car came with these, I presume they're the factory version since the caps say MINI on them, but I'll have to check the wiring to figure out why they don't turn on at all :/
Old Mar 28, 2010 | 05:36 AM
  #36
ronnie948's Avatar
ronnie948
Turn on procedure
Look for the switch on the left dash.
Turn on hi-beams and they should be on. They will only come on when your hi-beams are on. They will "NOT" light up when the low-beams are on.
Old Mar 28, 2010 | 08:56 AM
  #37
robinj's Avatar
robinj
the salesman at the dealership and I flipped every combination we could think of and the buggers wouldn't light up.. I'm fairly certain we tried the high beams with that button as well. *shrug*
Old Mar 28, 2010 | 10:47 AM
  #38
Fatherdeth's Avatar
Fatherdeth
I use the mounting brackets from Outmotoring and added the Hella Optilux driving lights with Angel eyes. They complement the Halo Headlights I have. Total cost was $110 and that was wayyyyy better than paying $400 from MINI.
Old Apr 15, 2010 | 08:43 AM
  #39
TSR53's Avatar
TSR53
I decided to craft and build my own designed brackets because of the currently designed brackets out in the market didn't offer the proper support, the correct location or size and weight of professional rallye lights I wanted to use.
I already had these stout professional spec PIAA 80 Racing lights taken off my Westfalia (with modded Hella Rallye 3000 covers - love the old school German graphics better).
Mounting them up
Location of these driving lights need to be at bumper level or higher for them to work and light up the road in front of you well. Also not blocking the upper or lower radiator grilles is important.
I didn't even drill any exposed holes into my front aero bumper cover to mount them, just made some small 1/4" size slices (into the grille and bumper cover) right in between the lower black grille and underside of the aero front bumper cover. The bumper cover slips over the brackets, and then you mount on the light brackets. With this set up you could mount the even bigger Hella 4000 Rallye, IPF 960 Rallye or any other larger more functional rallye lights. The brackets are bolted to the aluminum front bumper just in the right spot.
I still have to wire in the PIAA harness and will take my time on this. The fabricating of these rallye light mounts took me forever to make them just right!
These PIAA 80 Racing lights have H4 bulbs and each light is a 90w low beam AND a 135w high beam all in one. The metal housing and exceptional crystal clear lens make for a superb light. On the Vermont tarmac back roads I drive - essential.
More photos...
Old Jul 5, 2010 | 02:59 PM
  #40
danielthehero's Avatar
danielthehero
Does anybody know if it is possible to mount the OEM driving lights on the front bumper from the factory Aero Kit?
Old Jul 5, 2010 | 04:08 PM
  #41
anmracing's Avatar
anmracing
Mounting them up
More photos...
Great job! I like how yours sit lower.
A~
Old Jul 5, 2010 | 09:49 PM
  #42
dosomething's Avatar
dosomething
here is mine with VIP driving light kit. They mount on the bumper frame instead of the OEM hood mounted. I am happy with them.
Old Nov 30, 2010 | 09:31 AM
  #43
martinb's Avatar
martinb
Just discovered these lights:
https://www.bajadesigns.com/NET/P-61...+Driving+Black
In my humble opinion, they're the very best looking lights I've seen. Plus, they're rugged as all hell. As I see it, here are some of the advantages:
They're 35 watts like most good HID driving lights. But they have a 50 watt upgrade option as well.
The ballast is internally mounted.....just run the wires to them. No fooling with ballast mounting.
Cast aluminum housing with different color trim rings.
Glass lens.
Three point anti-vibration mounting with beam height adjustment.
Waterproof electrical connection.
Lifetime warranty.
And they're pretty small.
Look at page 6 of their catalog: http://www.bajadesigns.com/2009/catalog/
And then check out the rest of the catalog. There are some other awesome lights in there as well.
Old Dec 8, 2010 | 07:03 AM
  #44
Jazzop's Avatar
Jazzop
Does anyone know of a mounting bar that incorporates some sort of a "nudge bar" that projects forward of the actual lights? I don't want the lights to be the first point of contact for some douchbag trying to parallel park into the front of my car. And by douchebag, I mean every driver (except me) in NYC who parallel parks.
Old Aug 29, 2011 | 08:55 AM
  #45
bilal074's Avatar
bilal074
Grill...
Originally Posted by Fritzoc
I have the PIAA driving lights and fog lights. Ditched the plastic covers in favor of 3M clear stick-on protection. Love these lights, although I need to re-aim both sets.
Did you have to cut your grill? i have the JCW grill as well and i would be sad to cut through it. :(
Old Aug 29, 2011 | 09:49 AM
  #46
martinb's Avatar
martinb
I would never consider cutting that grill. There are always ways to design custom brackets to mount the lights and not hack anything. I haven't done it yet, but I have a design in my head for some brackets that would bolt to the heavy duty framework up front that holds the radiator and such and would not attach to the hood. They would stick out between the small gap between the bumper and the hood. One of these days......
Old Oct 1, 2011 | 06:51 PM
  #47
automan21's Avatar
automan21
I just got the VIP mounts on the car. Had to cut the grill but it wasnt so bad. Gotta install the lights now, maybe next weekend. I want to put black magic's on them.
Old Sep 26, 2014 | 01:10 PM
  #48
The Guarachero's Avatar
The Guarachero
Originally Posted by tazio
PIAA 520 SMR ~$250
Bigger and brighter than the 540s.
Available in chrome if you roll like that.
Will these work on a 2005 R50 mini cooper? And do they come complete with brackets? I have xenon lights so I'm not really going for the extra lighting, just the looks but I do plan on using them either way. What do you think?
Old Sep 26, 2014 | 01:12 PM
  #49
The Guarachero
Where did you get them? And for how much? Link please? (:
Old Sep 26, 2014 | 01:40 PM
  #50
martinb's Avatar
martinb
I still haven't gotten around to adding driving lights, but if I did, I now know what I'd install: http://www.clearwaterlights.com/infopg_erica.html
LED, dimmable, and capable of being wired up to the horn circuit so that they flash to full bright when you hit the horn.
