Interior/Exterior OEM Scoop on a CF Hood
Old Nov 27, 2009 | 05:58 PM
JohnnyVillan's Avatar
JohnnyVillan
Anybody know if the OEM scoops (or scoops designed to fit the OEM Hood) will fit ViS CF Hoods? Or anyone have pics of how the OEM scoops mount?
The scoop on my CF hood is turning yellow from the heat and is gonna need replacing soon. Thinking about getting a Hyper Blue scoop to match the rest of the car but Im not sure if it will fit or if I should just paint the scoop I already have.
Old Dec 1, 2009 | 09:44 PM
MaxMini81's Avatar
MaxMini81
Wanderer
I think it would look good, a sort of reversal on the CF on OEM. However, the pictures I have seen would lead me to believe that the CF hoods are a singular, molded piece. So there would be no need for the OEM part, and moreover no means to mount it.
When I was into Hondas, VIS always had the best looking kits, but they required HOURS of fitting - that is to say sanding down as they were very inprecise. The quality was never great either. Now, that was long ago, and fiberglass not CF. So I'm not trying to pass judgment or make a statement. I only bring it up to point out so that if you were thinking about modifying a CF hood to take the OEM scoop, you may already have a lot of work on your hands just getting it to fit.
Sweet website BTW
Old Dec 1, 2009 | 10:19 PM
JohnnyVillan
I already have the hood on the car (it fits like crap BTW) and the scoop is removable. I think its only like 3 bolts that hold it on. I have a justacooper so i dont know how the scoop on the stock S hood is attached.
Im kinda interested in the m7 scoops, I just gotta find out if ViS used the same mounting system as the stock hood. I know ViS makes a carbon fiber scoop for the stock hood, and that would lead one to assume that its the same scoop they give you when you buy the CF hood, and it mounts the same as stock.
Old Dec 2, 2009 | 05:16 AM
MaxMini81's Avatar
MaxMini81
Wanderer
PM'd
Old May 9, 2010 | 08:20 AM
AirborneMini003's Avatar
AirborneMini003
Johnny,
I think I have had the same issues as you with VIS's product, mind you, mine required less fitment but their customer service leaves something to be desired. From what I understand on the scoop and hood it is the same pins so same mounting. See the attachment which is supposed to be a Seibon scoop so figuring if yours looks the same you are good to go.
I am nervous about what you said with the yellowing. I know all carbon is doomed but it is also not all made equal. I can say that the parts I got from them looked ****, but WTF, yellowing with about 4 coats of clear?! Do you live in Arizona or something and park outside? How long did it take you? I am not trying to have to paint carbon in 6 months.
I have a solid hyper blue MINI with carbon mirrors so the originals are in the box. I also have the intention of swapping for a carbon scoop and may be tempted to part with my scoop soon.
Branto
Aug 11, 2017 05:32 PM
BRracing
Dec 22, 2015 09:25 AM
blackie
Oct 2, 2015 07:41 PM
FLYM1N1
Aug 16, 2015 01:15 PM
O4mcs
Aug 10, 2015 10:22 PM
