Interior/Exterior How to remove Interior parts?
I know Moss Mini sells a non-marring tool kit for these types of things. However, I don't know how its done.
http://www.mossmini.com/Shop/ViewPro...19&SortOrder=1
The parts you are talking about come off in two different ways.
The Secret compartment cover has two torx screws in it that hold it in place on the compartment hinge setup.
The cover behind the tach just pulls off. It has clips that hold it in place.
You have to pull a lot harder than you thing to get it off.
schatzy62 - Is there a DIY thread that gives directions for adding a hidden cig lighter plug for a GPS and routing instructions for the wires inside the dash panels up to the steering wheel area. I also want to run a hidden audio wire from the same location (GPS Mp3 player) to the aux input in the compartment at the bottom of the center stack.
I can't locate a thread that gives me directions.
For instructions on assembliing/disassembling just about any part of the car, get the BMW TIS manual on DVD from eBay (very cheap because they are all pirated copies).
Look at the pdf in this thread: https://www.northamericanmotoring.co...and-wheel.html. It describes 3 spoke to JCW but the procedure is the same.
xraycat
Aug 12, 2015 02:36 PM
Thanks I got the tread & figured it out.
